Member Teriander Posted December 24, 2015 Member Report Share Posted December 24, 2015 Has anyone had any issues where the geometry disappears when selecting the Sculpt room? My geometry looks fine in all the other tabs, but not in the sculpt room. It is totally missing. I do have "Show Voxels in paint room" checked on when in the Paint Room. Centering my camera also does not reveal my geometry. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted December 24, 2015 Reputable Contributor Solution Report Share Posted December 24, 2015 This might help explain what is going on: Quote Link to comment Share on other sites More sharing options...
Member pat_lane Posted January 11, 2016 Member Report Share Posted January 11, 2016 Has anyone had any issues where the geometry disappears when selecting the Sculpt room? My geometry looks fine in all the other tabs, but not in the sculpt room. It is totally missing. I do have "Show Voxels in paint room" checked on when in the Paint Room. Centering my camera also does not reveal my geometry. I have a similar problem when importing into the Voxel/Sculpt room. Where after clicking 'apply' and selecting a sculpting tool, the model completely dissapears. I have watched the 3D Coat overview videos kindly supplied by AbnRanger, although informative in the way of which room is related to each other the video's do not give any insight into dissapearing models in the sculpt room or what is causing the dissapearance. Any light onto this baffling nag would be greatly appreciated. Many thanks. Pat. Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted January 11, 2016 Advanced Member Report Share Posted January 11, 2016 Just wondering if your geometry is a object that you picked/choose (a 3dcoat premade) at the splash screen >Paint (per-pixel) then from the paint room tried sculpt room.? or is it a obj. imported in from another program? also When in sculpt room with the disappearing object go up to View > click on show poly object in sculpt room just wondering if that lets you see it is all. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 11, 2016 Report Share Posted January 11, 2016 It does occur to me that the object may be out of view range. Shift-A will bring it front and center. Quote Link to comment Share on other sites More sharing options...
Member pat_lane Posted January 12, 2016 Member Report Share Posted January 12, 2016 Thank you all very much for your ideas and very useful tips but after killing my pc last night with graphic driver updates, i.e DirectX and Open GL i believe the problem will be solved with the introduction of a shiny new graphics card with 'trigglagytes' of RAM on board. Having only used the Retopo room for the last several month until realising 3D Coat was much 'MUCH' more than that did the problem present itself. Soo, without further adoo.. I'm off down the shops to look at graphics cards Thank you very much for your help. Pat Quote Link to comment Share on other sites More sharing options...
