Advanced Member Ballistic_Tension Posted December 28, 2015 Advanced Member Share Posted December 28, 2015 (edited) watching the Vox Layer tutorial he has the football player arm and in the E panel chooses closed spline then draws spline across the arm around the whole/backside also . I am only getting 1/2 front of the arm. I can not figure how he marks through the back side of the model to get that full band around it ? I do have ignore backfaces on also tried it off.. in Voxel s mode also. I am using 4.5.03 now when I try too close the spline on last green square it just disappears . I am using the Closed Spline in the E panel mmmm Ok I had Depth Limit on turned that off also now all works thanks for the answers it was driving me crazy. Edited December 28, 2015 by Ballistic_Tension Quote Link to comment Share on other sites More sharing options...
Contributor Solution Tony Nemo Posted December 28, 2015 Contributor Solution Share Posted December 28, 2015 Ignore Backfaces must be off. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted December 28, 2015 Reputable Contributor Share Posted December 28, 2015 (edited) I tested on beta version 4.5.25 non-cuda 64 bit, Windows 7 64 bit and the voxel layer tool works correctly in both voxel or surface mode. I use the same tool as AbnRanger in the video but just made the control points hard. Ignore backfaces off in the e-panel. Attached image shows front and back view. Edited December 28, 2015 by digman Quote Link to comment Share on other sites More sharing options...
