Member MattVG Posted January 6, 2016 Member Share Posted January 6, 2016 Hello, I'm attempting to finish a rush job for a client, but am unable to retopologize the mesh due to "Faces deleted due to non-manifold in mesh." Then something about two faces overlapping. The message fades too quickly. It's a voxel sculpt I'm attempting to use autotopo on. How do I fix this? I've got to get this job finished within the next couple of hours! Thank you for your time, Matt VG Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted January 6, 2016 Advanced Member Share Posted January 6, 2016 1ST I would save what you have then you could try in sculpt room VOX TREE then where your mesh is under that Right Click brings up a long menu up near the top is To Global Space and /or To Uniform Space im not sure what the difference is betwwen the two try clicking on one of them .( if it in red on the bottom NON Uniform ) this will clear that up. I am not 100% sure on this hope it helps. 1 Quote Link to comment Share on other sites More sharing options...
Javis Posted January 6, 2016 Share Posted January 6, 2016 Good tip Ballistic. Also try converting whatever layer in the Voxtree you're trying to perform Auto retopology on to a voxel layer before running Auto retopology (this can be done by clicking on the S to convert to Voxels, or V to convert to Surfaces). If you need the polygons you can always convert back to surface mode. 1 Quote Link to comment Share on other sites More sharing options...
Member MattVG Posted January 6, 2016 Author Member Share Posted January 6, 2016 Thank you for your quick answers. Neither of those worked. I will try a combination of them though. Quote Link to comment Share on other sites More sharing options...
Javis Posted January 6, 2016 Share Posted January 6, 2016 Dang. Sorry Matt. Which build of 3DC are you using? I know you're on a tight deadline, but if you can sqeeze it, zip up the file and send it to me via PM. I'll see what I can do to help. 1 Quote Link to comment Share on other sites More sharing options...
Member MattVG Posted January 6, 2016 Author Member Share Posted January 6, 2016 I'm using 4.5.16. It's very odd because This is the second sculpt for this project I did today and the first turned out just fine. I'll PM you with a Dropbox link. I appreciate it. Quote Link to comment Share on other sites More sharing options...
Javis Posted January 6, 2016 Share Posted January 6, 2016 My pleasure Matt! I sent you my results via PM. I hope it helps. Quote Link to comment Share on other sites More sharing options...
Member Solution MattVG Posted January 6, 2016 Author Member Solution Share Posted January 6, 2016 For posterity, what Javis did to fix the issue he explains thusly: So I think I may have found the culprit, but I'm not entirely sure. I think it was the symmetry plane, which still isn't entirely set to world 0 across X, but what I did was turn off symmetry and ran it again, and it seems to have at least created the geometry. I didn't use any guides or paint density, just set the poly count to 20,000 polys and let it run. Before that, I also converted to surfaces, ran some other commands that I thought might help. I ran clean surfaces, weld vertices, cleanup memory, then saved just in case, and finally ran close holes. Then turned off symmetry, and ran Autopo, and it worked! Here's a file with mesh in the retopo room also (in fact, two meshes). I hope this helps. Note: I had previously attempted it with symmetry off and it didn't change the outcome for me. 2 Quote Link to comment Share on other sites More sharing options...
