New Member Marius Janusonis Posted January 8, 2016 New Member Report Share Posted January 8, 2016 Hello, Hello everyone, I'm new to 3D coat so sorry if I just can't find the solution on my own... I'm using 4k monitor and the user interface gets tiny and almost impossible to work on, same as it did on PS CS6 but Adobe fixed it on CC. However on 3D coat I just can't find any option to make UI bigger. Is there any way to work around this problem? Thanks for help in advance! Quote Link to comment Share on other sites More sharing options...
Member Justifun Posted January 21, 2016 Member Report Share Posted January 21, 2016 If you turn up windows scaling it seems to make things much easier to see https://technet.microsoft.com/en-us/magazine/ff629368.aspx Also if you need to try running microsoft cleartype or cleartext i forget the name. for clearer text if you need to. also i read somewhere else on the forum if you find the text blurry within 3d coat try right clicking the shortcut and goto properties->compatibility and check "disable display scaling on high DPI settings Quote Link to comment Share on other sites More sharing options...
New Member Marius Janusonis Posted January 21, 2016 Author New Member Report Share Posted January 21, 2016 Thanks, but windows scaling doesn't affect most of the softwares, just everything about windows and I'm using it because otherwise all the windows buttons and icons are too small too. Text is clear and not blurry at all, just small Quote Link to comment Share on other sites More sharing options...
