New Member SpazticusPrime Posted February 25, 2019 New Member Report Share Posted February 25, 2019 I'm having some difficulty with my install, trying to set up on a new computer (Max 2018, 3D Coat 4.8.32, Applink 2.1). Everything worked perfectly on my previous computer (same software, similar hardware). Then I switched computers and have to reinstall it all. Upon freshly installing Max 2018 I copied over my Max UI settings from the previous computer. Then installed 3D Coat. At this point I tried the Applink install as before, but I'm afraid it isn't installing. Everything appears exactly as though it's not running the mcr. I suspected the installer wasn't happy with something from my previous UI settings (perhaps a reference that looked like it's already installed) so I reset that to default and tried again (same result). And beyond that, I'm not sure what else to look for. Thoughts? Thanks! -Spaz Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 26, 2019 Reputable Contributor Report Share Posted February 26, 2019 8 hours ago, SpazticusPrime said: I'm having some difficulty with my install, trying to set up on a new computer (Max 2018, 3D Coat 4.8.32, Applink 2.1). Everything worked perfectly on my previous computer (same software, similar hardware). Then I switched computers and have to reinstall it all. Upon freshly installing Max 2018 I copied over my Max UI settings from the previous computer. Then installed 3D Coat. At this point I tried the Applink install as before, but I'm afraid it isn't installing. Everything appears exactly as though it's not running the mcr. I suspected the installer wasn't happy with something from my previous UI settings (perhaps a reference that looked like it's already installed) so I reset that to default and tried again (same result). And beyond that, I'm not sure what else to look for. Thoughts? Thanks! -Spaz Try to uninstall the old one and re-install the new one. I think I had a similar problem before, and IIRC, that is what fixed it. Quote Link to comment Share on other sites More sharing options...
New Member SpazticusPrime Posted February 26, 2019 New Member Report Share Posted February 26, 2019 9 hours ago, AbnRanger said: Try to uninstall the old one and re-install the new one. I think I had a similar problem before, and IIRC, that is what fixed it. Thanks AbnRanger, I'm trying that now. Just for the record, I should be installing the 2.1 rewrite from the beginning of this thread (not 1.8c from 3D Coat's download page), right? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 26, 2019 Reputable Contributor Report Share Posted February 26, 2019 7 minutes ago, SpazticusPrime said: Thanks AbnRanger, I'm trying that now. Just for the record, I should be installing the 2.1 rewrite from the beginning of this thread (not 1.8c from 3D Coat's download page), right? Yes. Whichever is most recent. Quote Link to comment Share on other sites More sharing options...
Member dniitall Posted March 17, 2019 Member Report Share Posted March 17, 2019 (edited) Max 2018 why, oh why did i try... 1.8 was working for me fine except the UV never came into 3DC so i UVed in 3DC 2.1 doesn't work at all. everything seems to work in Max but nothing ever comes into 3DC. and i've tried everything. it opens clean also, 1.8 had a very easy setup, like other scripts. seems i must go back to 1.8 Edited March 17, 2019 by dniitall Quote Link to comment Share on other sites More sharing options...
Member dniitall Posted March 18, 2019 Member Report Share Posted March 18, 2019 i was playing with the the temp folders and now it works to send to 3DC without UVs (not always, tho). sending back doesn't work Quote Link to comment Share on other sites More sharing options...
Member jfharper Posted May 1, 2019 Member Report Share Posted May 1, 2019 I'm on a new PC build, reinstalled max 2016 and coat 4.8.15D and applink v2.1, was able to export a mesh from max to 3d coat, and paint it, but the Export To menu item under File is missing. I think I saw this before but cannot remember how I fixed it...maybe something in the applink settings in max. Can someone offer a suggestion to try? Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted May 1, 2019 Applink Developer Report Share Posted May 1, 2019 @jfharper Can you see File -> Open in original App. That's the right menu when you bring something into 3d-coat. Quote Link to comment Share on other sites More sharing options...
Member jfharper Posted May 1, 2019 Member Report Share Posted May 1, 2019 26 minutes ago, haikalle said: @jfharper Can you see File -> Open in original App. That's the right menu when you bring something into 3d-coat. That worked...thank you. Quote Link to comment Share on other sites More sharing options...
Advanced Member MariuszKolo Posted May 12, 2019 Advanced Member Report Share Posted May 12, 2019 On 1/17/2016 at 2:32 AM, PolyHertz said: PSA: DO NOT USE EXPORT CONSTRUCTOR IN 3D-COAT! IT MUST BE DISABLED ON EXPORT FOR THE APPLINKS MATERIAL PRESETS TO WORK! It is possible to use the export constructor with multiple changes to the settings to get all names back to how they are by default, but it's not recommended. Hi, I am using 3d coat 4.8.37 for VFX with 3ds max 2018+vray3.6 and most of the time I have to transfer multiple paint objects with multiple UV sets and textures at once between apps. The textures have to have unique prefix in the names based of paint object name. Currently I am exporting them from 3d coat with export constructor and I am building shader networks in 3ds max manually but it is a huge waste of time. There have to be a way to automate it. I watched youtube tutorials for max applink 2.1 and tested it. The included preset in Applink 2.1 for Vray don't work in my end and I tried to create a custom one without success. Even if I don't use export constructor and I would like to export 20 paint object at once the applink and preset don't work how it should. Tutorials also don't show the case where you would like to transfer let say 20 paint object with diffuse, IOR, glossiness, specular color, and normal map at ones in 3ds max.Since export constructor in 3d coat have to be disabled by recommendation how make it possible to export 20 paint objects with deferent uv sets at ones?Would someone be so kind and explain it how to do it or maybe add feature to applink to be able to use constructor with multiple paint objects and based of names of paint objects and corresponding export folder for them create and assign Vray 3.6 shaders in 3ds max 2018 with help of applink ? I would be very greatful for help because I am have very short deadlines and a lot of objects to transfer from 3dcoat paint room to 3ds max+vray.Could someone from applink developers could contact me and we could together figure it out? I think that would benefit all 3ds max applink users. Best regards Mariusz PS. It is no easy to find app link v2.1 and documentation about it since https://3dcoat.com/download/applinks/ 3ds max is pointing to version 1.8c. Could someone fix it ? Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted May 16, 2019 Applink Developer Report Share Posted May 16, 2019 (edited) @MariuszKolo Are you still without an answer? @PolyHertz Edited May 16, 2019 by haikalle Quote Link to comment Share on other sites More sharing options...
Advanced Member MariuszKolo Posted May 16, 2019 Advanced Member Report Share Posted May 16, 2019 Yes- I haven't heard any reply or any help from 3d coat team side Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted May 16, 2019 Applink Developer Report Share Posted May 16, 2019 I hope that @PolyHertz see this. Usually he is very fast to respond. I tried to take a look but I'm not able to see the code so I can't say what's going on there. Quote Link to comment Share on other sites More sharing options...
Advanced Member MariuszKolo Posted May 16, 2019 Advanced Member Report Share Posted May 16, 2019 Thank you very much for good intensions Haikalle:) Quote Link to comment Share on other sites More sharing options...
Member IvanMax33 Posted September 28, 2019 Member Report Share Posted September 28, 2019 Hello, My 3dcoat v.4.8.42 do not see export from 3dsmax applink whatever temp folder i set. I tried each and every solution in this topic but it just opens automatically from applink export button and show me welcome screen. All files are properly created by applink. My 3dcoat is installed in C:\Program Files\3DCoat-V4.8.42 3dcoat data folder is by default set to D:\DOCUMENTS\3D-CoatV48 Applinks folder with Maxsetting folder by default is in C:\Users\***\Documents\AppLinks Where should i set temp folder in 3dsmax applink so 3dcoat can see export files? Please, help! Quote Link to comment Share on other sites More sharing options...
Member IvanMax33 Posted September 28, 2019 Member Report Share Posted September 28, 2019 ***I CAN CONFIRM! 3dsmax Applink 2.1 is broken!*** My solution: Use 1.9 instead Set temp folder to : D:\DOCUMENTS\3D-CoatV48\Exchange.(3dcoat default data folder) Everything works perfectly! Quote Link to comment Share on other sites More sharing options...
Member IvanMax33 Posted September 28, 2019 Member Report Share Posted September 28, 2019 Please! Update Applink! 2.1 is close to its perfect state in terms of workflow but just don't work. 1 Quote Link to comment Share on other sites More sharing options...
PolyHertz Posted October 9, 2020 Author Report Share Posted October 9, 2020 Hey everyone, been quite a while since my last post. With the upcoming release of 3D-Coat 2021 (aka. v5.0) I thought it might be time to update this applink. That said, I'd like to first know; Is there still any interest in this? If there's no interest anymore then there's no reason for me to spend time updating it after all. 1 3 Quote Link to comment Share on other sites More sharing options...
Advanced Member puntoit Posted October 11, 2020 Advanced Member Report Share Posted October 11, 2020 Hi Polyhertz, I think it is a valuable tool and would miss it if it where to be gone. If you decide to do an update and need help on the translations, just let me know. Cheers, Mike Quote Link to comment Share on other sites More sharing options...
Member superman punch Posted November 25, 2020 Member Report Share Posted November 25, 2020 It's really necessary and it's very good. Thank you. I hope the next version will be able to move to fbx. Please. Quote Link to comment Share on other sites More sharing options...
Member Northvs Posted December 24, 2020 Member Report Share Posted December 24, 2020 Does the Applink work for 3ds Max 2020 & Vray? It only works going from max to 3d Coat. Quote Link to comment Share on other sites More sharing options...
New Member ebhance Posted January 5, 2021 New Member Report Share Posted January 5, 2021 @PolyHertz Thank you for asking, yes hoping to use the applink with Max 2021. -Eric Quote Link to comment Share on other sites More sharing options...
Member ScoobyDoofus Posted March 11, 2021 Member Report Share Posted March 11, 2021 @PolyHertz Yeah man! I still use it and just upgraded to 3DS 2021 + Latest 3D Coat. Thanks for all your efforts on this so far! Quote Link to comment Share on other sites More sharing options...
Member Fletcher Kinnear Posted August 12, 2021 Member Report Share Posted August 12, 2021 There's still a pretty annoying bug where exporting an object to 3D coat resets the "Use Z up coordinate system" setting in 3D coat and there's absolutely no way to change/fix this. If I manually import an object while Z-up is enabled in 3dc it imports fine, but if I use Applink it resets it every single time so the object comes in with the wrong orientation. Quote Link to comment Share on other sites More sharing options...
Member Okkio Posted September 6, 2021 Member Report Share Posted September 6, 2021 Update Applink for 3dsmax 2021 please! It's most important for don't waste the time in wrong relocation maps from 3dcoat to vray! Please.... Plase ... Please! Quote Link to comment Share on other sites More sharing options...
New Member renatokg Posted March 8, 2022 New Member Report Share Posted March 8, 2022 also just waiting for it for 3smax 2022 and the latest 3dcoat Quote Link to comment Share on other sites More sharing options...
New Member cnrk Posted October 30, 2022 New Member Report Share Posted October 30, 2022 Hey, Can I send re-topo mesh from 3d coat to 3ds max? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 1 Report Share Posted April 1 Evil_Weasel: ancient 3ds max applink from forum works fine, even though it is like 5 years old. Quote Link to comment Share on other sites More sharing options...
New Member nichamilton Posted yesterday at 06:14 AM New Member Report Share Posted yesterday at 06:14 AM is there a version of this that works with max 2024? only blender on webpage is 3Dcoat still being developed? i would like to buy it but this forum seems dead and looking for tips on where to get started. very confusing software lol... Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted yesterday at 11:27 AM Report Share Posted yesterday at 11:27 AM 5 hours ago, nichamilton said: is 3Dcoat still being developed? If your question is about the 3ds Max applink, then it is under development. For general questions about how 3Dcoat works, ask them, they will be happy to help you. Quote Link to comment Share on other sites More sharing options...
