Transforming multiple layers
Nidhogg
Go to solution Solved by Michaelgdrs,
It depends , you can start with a base layer and adding them there , if you have a submarine with lots of parts for example it will work well for your needs.
When you import you can check
1) Import to separate instance so its gets them parented automatically. (3d model with multiple parts will go all as childs on one layer)
2) Import as child so it gets it parented to the existing layer. (gets the imported model as a child)
