Thickness setting for blob brush
Justifun
When using the blob brush to create initial voxel shapes, it would really handy to be able to set a thickness of the object in the tool options when you hit enter to build the shape.  Right now they all come in at the same thickness.  Scaling them with the transform tool afterwards creates a lot of jaggies along the edges even after using the "to uniform space" command.
Ideally if there was a checkbox as well that would allow the following options of the thickness.
A) insert a straight area between the Round/Plane/Sharp borders eg: (____________)
B) make the object as thick as you set, but the rounding borders etc would still stretch from the widest point of the object, back to the center line of it.
Thanks!
  • 1 month later...
I was wondering about blob thickness. Read somewhere else on these forums that you can just adjust your brush size to increase blob thickness (if using a border mode you'll need to adjust this accordingly)
You can't right click + drag to adjust brush scale in Blob mode though, so you'll need to do it at the top menu where it says "Radius", which is essentially the same as entering a thickness numeric value.
Edited by Gary Dave
