Advanced Member b33nine Posted January 28, 2016 Advanced Member Report Share Posted January 28, 2016 Is there a way to set up the split and joint tool in a way that you can feed it a positive and a negative model to generate your joint? Alternatively, is it possible by chance to have the joint be a shape so that it can only go back together in the way it was split? Something like the profile being a quadrilateral that's got a wide base and a narrower top? I really like the split/joint tool, but would like to use it in a way that you can only put a printed model back together in the way it was built originally. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted January 29, 2016 Reputable Contributor Report Share Posted January 29, 2016 (edited) EDIT: I removed my answer as I again read your statement again and the answer did not apply. Edited January 29, 2016 by digman Quote Link to comment Share on other sites More sharing options...
Advanced Member b33nine Posted January 31, 2016 Author Advanced Member Report Share Posted January 31, 2016 Safe to assume this isn't currently possible? If it were that split/joint tool would make 3d-coat amazing for 3d printing (not that it already isn't pretty amazing for it). Quote Link to comment Share on other sites More sharing options...
