GradeSchool
curve strokes tool- backfaces
I am using the pinch tool with the curve strokes setting. I use this setup often, and I'm seeing some strange behavior.
I lay down a curve, press enter. The pinch happens on the back side of the model, not under the curve stroke. I have checked the e panel setting, turned off smooth back faces, turned on and off ignore back faces, still getting super odd results. Also turned on and off the Invert Tool checkbox...
I am working with a 3d scan, multiple parts, in both voxel and surface mode. I thought this might have something to do with my issue, but if I use the pinch tool with any other "brush" e panel setting, it works fine. If I use the curve strokes in either voxel or surface- same problem...
Seems like the curve strokes setting might be broken? Or maybe a setting I'm not familiar with?
Thanks in advance!
4.5.28 (CUDA) (DX64) win 7 64
OK,
I did another test with a default file, and I believe it's my 3d scan that is causing the issue. VERY Strange.
I load my file. I have a layer of my project I am working on. I try to curve stroke Pinch a section. It pinches the opposite side of the model (I believe through the normals, not screen space). Symmetry is off.
I convert that layer to voxels and try again. Same problem.
I've flipped the normals just to test, then flipped them back. Same problem.
Same project- add a voxel sphere on a new layer- try a test, the curve stroke works properly.
Again- the problem is only with curve strokes- not any of the brush e panel settings. Driving me bonkers!
