Copy [objects] along path?
Seven Are They
Go to solution Solved by TimmyZDesign,
  • Solution
Use the Curve Tool. You can also create your own objects and then have them repeat over the length of the curve. Check out the Splines panel and the Models Panel. You put your custom objects in those panels, and then you can choose them for use in the Curve Tool.
