Kargall
Problem shader
Hi,
I have a problem with some shader that seem to reverse the normals of my model. Do you have a solution to this?
Thank you
post-2367-0-25484400-1463186922_thumb.jp
post-2367-0-99244400-1463186936_thumb.jp
Could you share the shader to take a look ?
post-10142-0-65088700-1463191524_thumb.j
Yes !
It's here :
http://3dcoat.com/download/#4
GreyWaxA for exemple .But there are many other. I think this is my mesh that is not correct.
With some default shader that does not work either. For ex: Bone or clay or greenclay.
THX
I cant find any trouble with waxA shaders. The head have surface paint ?
Could you share the head ?
Not of paint on the surface of the head. This is a problem between the mesh and the "Flat Shading" of shader. :unsure:
Testing all the PBR shaders using the last vesion 4.5.38.
cant replicate your problem
Mi primary and contrast light are = 100
render room. exposure and environment light= 100
try to export the Tete (RMB >Export > export Object)
And import it in a new layer (RMB >Import > import Object)
any change ?
Well! . I did as you advised me. Import / export mesh and it works now. It's Ok ! I would have liked to know why. But, well. Thank you very much Carlosan . :drinks:
