Airship
Awiz
Hi !   :)
To Gary Dave:
Thanks !
For grids  -   I  used  a sphere tool  (in voxel mode)  with a curve  stroke  -  it automatically repeats the form of the surface
post-40442-0-87793700-1463559200_thumb.j
For a frames  -  I  use  vox layers.
  • Like 3
that mesh/netting looks great how you get it so thin and spaced right is that free handed? what brush radius did u use 4.50 .   just me but the 2 stacks could be bigger /wider like queen mary big . also how many triangles when doing net  looks to be at 350,000 . Looks great so far.  also  how it repeats the form
Edited by Ballistic_Tension
Hi  all !!   :)
Thanks to everyone who is looking for my work :)
about the net  --   summary contains  ~7.600.000 triangles
post-40442-0-16401200-1463935981_thumb.j
when I did the network - I have used voxel layer with a high density [8x] or [16x]  and sphere  brush  with a small radius (I select approximately - doing a few tries   :) )  -  I paint in several stages - and combined in a single layer --  at the end I use resempler - and reduce the number of triangles to a reasonable level for me.
for drawing smoothly and in regular intervals, I'm doing extra geometry in a ghostly layer
post-40442-0-46539300-1463937398_thumb.j
and the surface shape is repeated automatically -  if used  a curve  stroke -  I showed  example  earlier   :)
about  stacks  -  Queen Mary is more modern example of what I use ( it seems to me) -  for references  I look  fotos a steamships at the end of the 19th century or beginning of 20 century  -  like  this
http://heiup.uni-heidelberg.de/journals/index.php/transcultural/article/viewFile/9363/3245/10355
or  this
http://3.bp.blogspot.com/-3m09K3n43Uk/U_eEXThrn4I/AAAAAAAAEEA/Nlv1nP1PvvI/s1600/Gondolier%2BDrawing%2B1.JPG
or this
https://thedisorderofthings.files.wordpress.com/2015/02/steamship_islander_leaving_vancouver_british_columbia_for_skagway_bay_crop.jpg
I think it is more suitable for steampunk ( it seems to me)
P.s.   I  use  Google translate  :)
Edited by Awiz
Hi  all !! :)
I was a little busy - so this is a small update :)
ropes to the ground (to anchors) are not done yet - on the picture they are just for illustration purposes
  • Like 2
