Reputable Contributor AbnRanger Posted June 5, 2016 Reputable Contributor Report Share Posted June 5, 2016 It's looking really good thus far. I do agree with the one other person who mention the scale of the vertical stacks. They are fine as is, but perhaps exaggerating the scale of them quite a bit more, could help sell the whole Steampunk aspect even more? Maybe not, but could be worth a brief attempt. 1 Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 6, 2016 Author Member Report Share Posted June 6, 2016 9 hours ago, AbnRanger said: It's looking really good thus far. I do agree with the one other person who mention the scale of the vertical stacks. They are fine as is, but perhaps exaggerating the scale of them quite a bit more, could help sell the whole Steampunk aspect even more? Maybe not, but could be worth a brief attempt. Thanks! I will try to explain my opinion : Although a steampunk is a fantastic direction - I like realistic-looking modeling style. In my mind, I imagine that this airship can not have too large steam engine - respectively, and smokestacks should not be too large . I believe that the engines and mechanisms need to be compact and light that they can be lifted into the air and at the same time remained the possibility of carrying passengers with comfort. In my imagination, airship construction is made of more advanced, light and durable materials - that allows give it a form of what I represent, and the internal volume of up to ~80-85% busy of a balloons with lifting gas. And according to these ideas, I choose the proportions of all the elements of the airship - and I try to combine the fantastic and realistic ideas in this my work You be the judge happened or not - but I personally like the way that there are. I hope, I have correctly expressed my idea Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 6, 2016 Contributor Report Share Posted June 6, 2016 Very soundly reasoned! I must agree. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 6, 2016 Reputable Contributor Report Share Posted June 6, 2016 5 hours ago, Awiz said: Thanks! I will try to explain my opinion : Although a steampunk is a fantastic direction - I like realistic-looking modeling style. In my mind, I imagine that this airship can not have too large steam engine - respectively, and smokestacks should not be too large . I believe that the engines and mechanisms need to be compact and light that they can be lifted into the air and at the same time remained the possibility of carrying passengers with comfort. In my imagination, airship construction is made of more advanced, light and durable materials - that allows give it a form of what I represent, and the internal volume of up to ~80-85% busy of a balloons with lifting gas. And according to these ideas, I choose the proportions of all the elements of the airship - and I try to combine the fantastic and realistic ideas in this my work You be the judge happened or not - but I personally like the way that there are. I hope, I have correctly expressed my idea Understood. It was just an idea, from the perspective that we often tend to prefer style over functionality, and in films like SteamBoy, things trend toward exaggeration rather than the believable. However, I do notice a lot of Robot sculpts, out there, that seem to focus more on adding excessive amounts of detail, rather than letting form follow function, so I can certainly see where you're coming from. 1 Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted June 6, 2016 Contributor Report Share Posted June 6, 2016 I like it. Good work. 1 Quote Link to comment Share on other sites More sharing options...
Member BubbaDaCaveman Posted June 7, 2016 Member Report Share Posted June 7, 2016 Hi Awiz, I understood most of what you said, but could you explain step by step how you get the repeated curves. Do you create one curve and then somehow duplicate it in regular intervals? I believe I could really benefit from that knowledge, if you would tell me And great job mate. Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 7, 2016 Author Member Report Share Posted June 7, 2016 1 hour ago, BubbaDaCaveman said: Hi Awiz, I understood most of what you said, but could you explain step by step how you get the repeated curves. Do you create one curve and then somehow duplicate it in regular intervals? I believe I could really benefit from that knowledge, if you would tell me And great job mate. Hi ! I will try to explain how I do creat a base form create and deploy temp object next use warp tool and make as many copies as you need and with the required intervals switch temp object to ghost mode in voxtree select desired point of view correct position temp object if it need select sphere tool and curv stroke mode add new layer voxel mode draw some strocks - one curv but some stroke uncheck Draw from first point hide if it need temp object press enter result cut off the excess finish repeat and combine multiple times if necessary I hope I have correctly understood the question and answered it clear 4 Quote Link to comment Share on other sites More sharing options...
Member angecroft Posted June 7, 2016 Member Report Share Posted June 7, 2016 Nice explanation ! I have so much to learn I'm not sure I will use it on my own piece but really interesting approach anyway. 1 Quote Link to comment Share on other sites More sharing options...
Member BubbaDaCaveman Posted June 7, 2016 Member Report Share Posted June 7, 2016 (edited) Thank you very much Awiz for sharing your tips and techniques Edited June 7, 2016 by BubbaDaCaveman 1 Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 11, 2016 Author Member Report Share Posted June 11, 2016 Hi all ! update 7 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 11, 2016 Contributor Report Share Posted June 11, 2016 Super! 1 Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 11, 2016 Author Member Report Share Posted June 11, 2016 Thank you so much! Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 11, 2016 Author Member Report Share Posted June 11, 2016 (edited) I read a neighboring forum thread - which discussed the question of how much is used 3d coat in the competitive work. And just in case, I would like to say that I use only 3d Coat and Photoshop for the final processing of the rendered image. Edited June 11, 2016 by Awiz grammatical errors Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 19, 2016 Author Member Report Share Posted June 19, 2016 (edited) Hi all !! Here is my final images Edited June 19, 2016 by Awiz 4 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted June 19, 2016 Advanced Member Report Share Posted June 19, 2016 Boy I had tried to do the netting on and off 2,3,4, times then I gave up. So with this explanation I will be able to do it . Thanks a bunch to take the time. Its such a great effect / look that I just have to learn it. Your model looks great and the smoke effect. Quote Link to comment Share on other sites More sharing options...
Member pauloduarte Posted June 20, 2016 Member Report Share Posted June 20, 2016 Amazing work, one of the best entries, I would love to do a trip in this airship. 1 Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted June 23, 2016 Author Member Report Share Posted June 23, 2016 On 20.06.2016 at 4:29 AM, pauloduarte said: Amazing work, one of the best entries, I would love to do a trip in this airship. Thanks! Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted July 18, 2016 Moderator Report Share Posted July 18, 2016 I like the last image. I couldn't see shadows from those guys on the ground Maybe you could work on shadows a bit more? And some color toning...? Also I think that it would be better to keep more space from the sides of the airship (make scene wider). All is my imho )) Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted July 18, 2016 Contributor Report Share Posted July 18, 2016 I thought the 'men' were mere icons to give scale to the ship. Quote Link to comment Share on other sites More sharing options...
Member Awiz Posted July 19, 2016 Author Member Report Share Posted July 19, 2016 19 hours ago, Tony Nemo said: I thought the 'men' were mere icons to give scale to the ship. Hi ! exactly - "men" figures for the scale. I do not know how to make beautiful models of people and make ugly I do not want Daniel Also I think that it would be better to keep more space from the sides of the airship (make scene wider). All is my imho )) Like this Quote this is again to emphasize the scale of the airship . I just love the model of any machinery - with the rest I do not very successful Daniel And some color toning...? - can You write more ? - What did you mean? Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted July 29, 2016 Moderator Report Share Posted July 29, 2016 Just google for "photo color toning" or similar Quote Link to comment Share on other sites More sharing options...
