Member CognizanCe Posted May 24, 2016 Member Report Share Posted May 24, 2016 I'm now realizing a mesh I imported to the sculpt room was moved and scaled by accident.How do I reset the mesh position and scale to where it was when I originally imported? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 24, 2016 Report Share Posted May 24, 2016 Adjustment Tools Transform This tool lets you rotate, scale and translate your currently selected layer in the VoxTree. By grabbing one of the gizmo handles you can constrain to whatever axis you clicked. You can also perform a screenbased rotation using the large outer ring. Let’s look at the options for this tool. Move Only Gizmo: Lets you make adjustments exclusively to the gizmo. This helps when you need to place the gizmo in another location. Leave Rotated Axis: This is great for when you need to rotate an object multiple times while retaining its previous rotations. Position & Axes (1,2 & 3): These parameters let you manually key in the position and rotational coordinates. Scale (X, Y & Z): These parameters allow you the manually key in scalar modulations. Reset Axis/Space: These two functions let you reset an object’s axis or local space. Quote Link to comment Share on other sites More sharing options...
Member CognizanCe Posted May 24, 2016 Author Member Report Share Posted May 24, 2016 Adjustment Tools Transform This tool lets you rotate, scale and translate your currently selected layer in the VoxTree. By grabbing one of the gizmo handles you can constrain to whatever axis you clicked. You can also perform a screenbased rotation using the large outer ring. Let’s look at the options for this tool. Move Only Gizmo: Lets you make adjustments exclusively to the gizmo. This helps when you need to place the gizmo in another location. Leave Rotated Axis: This is great for when you need to rotate an object multiple times while retaining its previous rotations. Position & Axes (1,2 & 3): These parameters let you manually key in the position and rotational coordinates. Scale (X, Y & Z): These parameters allow you the manually key in scalar modulations. Reset Axis/Space: These two functions let you reset an object’s axis or local space. Was supposed to post this here: Zero set it to 000 on the world position. Reset button gives some random position. Pressing undo and re-do enough times causes 3d-Coat to crash. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 24, 2016 Report Share Posted May 24, 2016 Your project causes random crash with different operations. To recover your project please contact support@3dcoat.com Quote Link to comment Share on other sites More sharing options...
