Looks like the 3D-Coat forums are being updated silently in the background even as I'm writing this.
Webmaster, which version of IP.Board have you updated to?
Cheers,
AgentSam
Edited by AgentSam
Hi
Forum was upgraded to V4.
Webmaster is working on it.
We are sorry for any inconvenience caused.
@Carlosan: Does your own post look like this on your screen?
EDIT: Noticed you just fixed your post... now it looks normal. (The picture above no longer reflects the latest situation.)
Edited by AgentSam
Updated to reflect current status...
Looks like the new version supports BB-code directly, without having to switch to BB-Code mode.
I wonder what new BB-code tags are supported... Also, is the new version fully backwards compatible with the previous version?
Webmaster will continue the upgrades tomorrow.
we need to wait a little more to be fully backwards compatible with the previous version :)
ty !
@Carlosan: OK, no worries, I'm sure he's doing his best.
He should propably reset or delete some of the bug reports concerning forums, on the Mantis website too. (Although there's only one, and it was reported by me a few weeks ago. Now that report is no longer valid, because everything has changed.)
One additional question comes to mind...
Does the webmaster intend to restore the legacy "Dark 3D-Coat Theme", which was available in the old forum version? I loved that dark theme.
Cheers,
AgentSam
Love the new look , great job
@Tony:
I sort of understand if the Webmaster doesn't want to implement additional themes, because it will require more maintenance, and there are other problems with the themes also.. One of which is "font colors".. the rich text editor allows users to set background and foreground colors for the text that they write, and if someone uses the light theme, but sets a dark font color, then people using the dark theme will be having a hard time seeing that text... And vice versa.
But - I don't think I could live without the dark theme (this bright color hurts my eyes), so I'm considering implementing some custom dark forum styles as a Greasemonkey script that anyone can install and use if they like.
Cheers,
AgentSam
3 minutes ago, Tony Nemo said:
I look for the return of the dark theme.:mellow:
Me too.  :o
Applying the attached stylesheet will give you the following.
I didn't remember exactly what the old dark-theme looked like, so I just tried to get it as close to it as possible.
This was tested in Firefox. To apply the user style-sheet, you need to save the attached .CSS as "userContent.css" into a "Chrome" subfolder inside your Firefox profile folder.
Note: This was just a quick fix for my personal use; and I'm sure I didn't catch all of the new IP.Board color-definitions yet. It may be better to wait for the official Dark-Theme. This is just for those people who know what they're doing.
Cheers,
AgentSam
userContent.css
I have installed dark theme - Titanium 4x. You can choose it at the bottom of the page.
Much appreciated, easy to apply and much easier on the eye
Please make dark theme the default, because bright white is incredibly hard on the eyes. It is why more and more CG apps are going with a darker grey theme. More light blasting the eyes punishes the eyes when you are sitting behind a monitor all day. AJZ had an awesome theme. Dark Grey with the accessories in Teal like the rest of the website.
Same here, the Dark theme is much better for the eyes.
Anybody else cant see the images from the top row gallery?
This new version of IP.Board is great! My thanks to the webmaster for doing the update.
There are so many small things that make this version better; like that visual separator between read and unread content.
The new "Activity" displays are pretty decent also...
However, I just had to minimize some of those margins and padding, because they were just crazy - so much empty space taking up my screen real-estate. Just had to.
But all in all, I have to say this forum update was worth it from the end-user perspective.
Cheers,
AgentSam
QUESTION: Is it possible to limit the size of images when posting?
For example, when posting screenshots using embedded IMGUR links, the images look huge in the post. It would be nice to be able to scale them down a bit; in a way that they are shown smaller in the posting, but become larger/fullsize when clicked.
Can this be done? Without using the built-in attachment feature, which has a limited size quota per user.
Cheers,
AgentSam
Quote
Cheers,
AgentSam
Please post here some big screenshots using embedded IMGUR links. Thanks.
my thoughts on the web page layout. I would like to be able to collapse the Images, Topics, and Post  headers.  The  Topics and Post  Headers  I don't need at all. Having the same information  in 3 different areas is redundant . thank you for the dark theme :D
36 minutes ago, Ballistic_Tension said:
My thoughts on the web page layout. I would like to be able to collapse the Images, Topics, and Post  headers.  The Topics and Post  Headers I don't need at all. Having the same information  in 3 different areas is redundant . thank you for the dark theme :D
I think you just got your wish granted... Because I can no longer see the "5 Latest Topics" and "5 Latest Posts" panels at all. And I agree they were a bit redundant, because the easiest way to check for latest content is still by using the "Unread Content" stream, which is what I use all the time.
The Images banner should be collapsable.
If I remember correctly, in the old V3 forums, the latest Topics and latest Posts panels were collapsable.. (there was a triangle button that collapsed the entire side-panel section).
Edited by AgentSam
On my screen, the forum index now looks like this (with some custom CSS tweaks):
@webmaster:
There's something weird going on with the quote you used earlier.
Take a look:
There are a couple of easy ways to fix it...
Either set max-width to 100%:
.ipsType_richText .ipsContained {
    max-width: 100%;
Or enable scroll bars on overflow, in the container:
ipsQuote_contents {
  overflow: scroll !important;
Edited by AgentSam
