Japanese translation state
Andrew Shpagin
As you maybe know, half of year ago Japanese translation was almost ready. Text was translated by our Japanese resellers. But that time several problems appeared - licensing issue, then health problem of reseller... After several months of frozen situation we decided to buy Japanese translation and stop contract with Japanese reseller. So, we have bought Japanese texts. But there are only 74% of text because I have add many text since that time. So we have add Japanese translation page with 74% of translated text. So, if you have time and desire, please help with translation of the rest 26%.
www.3d-coat.com/index_translation.p...nguage=Japanese
Excuse for so long delay with this question. I can't tell that resellers have made something too wrong, really there was force-major obstacles on them side.
Btw, you description of voxels on your site is excellent!
Thank you. :)
The volume modeling of 3DC is more pleasant than any kind of other software! :lol: :lol: :lol:
3.00ALPHA-42(DX)
WinXP Pro sp2 32bit
Dual-Xeon3G HT
3G Ram
RadeonX1950
http://www.k2.dion.ne.jp/~output/c/3d-coat.html
  • 4 months later...
Hi! Andrew.
A Japanese text cannot not be encoded, and the text be read on the Japanese translation page now.
Japanese XML is also the same.
It has been understood that I am all the same when I hear this symptom in a Japanese forum.
Did you change any settings?
  • 1 month later...
Hi Andrew.
We are unavailable "Download japanese.xml" in "ExportJapanese.xml".
Here is error message below.
Warning: filesize() [function.filesize]: Stat failed for /var/www/vhosts/3d-
coat.com/httpdocs/files/xml_translation/Japanese_Bancho_2009_06_18 16:28:50.xml (errno=2 - No such file or directory) in
/usr/home/3dbrush/data/www/3d-coat.com/get_xml_translation.php on line 8
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/3dbrush/data/www/3d-
coat.com/get_xml_translation.php:8) in /usr/home/3dbrush/data/www/3d-coat.com/get_xml_translation.php on line 10
coat.com/get_xml_translation.php:8) in /usr/home/3dbrush/data/www/3d-coat.com/get_xml_translation.php on line 11
coat.com/get_xml_translation.php:8) in /usr/home/3dbrush/data/www/3d-coat.com/get_xml_translation.php on line 12
coat.com/get_xml_translation.php:8) in /usr/home/3dbrush/data/www/3d-coat.com/get_xml_translation.php on line 13
Warning: readfile(/var/www/vhosts/3d-coat.com/httpdocs/files/xml_translation/Japanese_Bancho_2009_06_18 16:28:50.xml)
[function.readfile]: failed to open stream: No such file or directory in /usr/home/3dbrush/data/www/3d-
coat.com/get_xml_translation.php on line 15
Hi Andrew.
It works now. Please check it.
