Member Dennis Nikolaidis Posted May 31, 2016 Member Report Share Posted May 31, 2016 I'm having an issue with custom shortcuts. When I assign one and try to use it, it only selects the tool for a split second and goes back to the previously selected tool. What is the problem? 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 31, 2016 Report Share Posted May 31, 2016 Hotkey is already assigned ? By pressing the “End” key on your keyboard while hovering your cursor over the tool or function, you can then define which key you want it to be assigned to. If a hotkey is already assigned you will be asked if you wish to stack the tool/function with any previous tools/functions, allowing you to cycle between all of the tools with one hotkey. Quote Link to comment Share on other sites More sharing options...
Member kait kybar Posted July 18, 2016 Member Report Share Posted July 18, 2016 (edited) I have the same problem. selects the tool for a split second and goes back to the previously selected tool. Edited July 18, 2016 by kait kybar 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 18, 2016 Report Share Posted July 18, 2016 Hello. are you using the last stable version 4.7.06 ? ---------------------------------------------------------- Do you have assigned any stack key combination ? Hotkeys Nearly every tool and function in 3DC can be hotkeyed. By hovering your cursor over the tool you will see the following text, “(‘END’ – Define hotkey)”. By pressing the “End” key on your keyboard while hovering your cursor over the tool or function, you can then define which key you want it to be assigned to. If a hotkey is already assigned you will be asked if you wish to: Reassign the key with the new tool/function Stack the tool/function with any previous tools/functions, allowing you to cycle between all of the tools with one hotkey Remove any tools/functions assigned to that key Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted July 18, 2016 Advanced Member Report Share Posted July 18, 2016 I get this problem with the Transform key (T) It works from the left menu but occasionally the T key does not accept the press so to speak,the gizmo flashes on for a brief moment . Though I have found if I tap T twice in quick succession it seems to accept it ? Dennis ,try tapping twice just to see.See if it works for you... Quote Link to comment Share on other sites More sharing options...
Member kait kybar Posted February 1, 2017 Member Report Share Posted February 1, 2017 Hello. its back! I have no idea why its happening. any solution? 1 Quote Link to comment Share on other sites More sharing options...
Member kait kybar Posted February 1, 2017 Member Report Share Posted February 1, 2017 Alright, I dont know what is the problem but one solution is to delete 3d coat from my documents (yeah, better backup your stuff first) and reinstall it. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 1, 2017 Report Share Posted February 1, 2017 Do you have assigned any stack key combination ? Nearly every tool and function in 3DC can be hotkeyed. By hovering your cursor over the tool you will see the following text, “(‘END’ – Define hotkey)”. By pressing the “End” key on your keyboard while hovering your cursor over the tool or function, you can then define which key you want it to be assigned to. If a hotkey is already assigned you will be asked if you wish to: Reassign the key with the new tool/function Stack the tool/function with any previous tools/functions, allowing you to cycle between all of the tools with one hotkey Remove any tools/functions assigned to that key Quote Link to comment Share on other sites More sharing options...
Member kait kybar Posted February 2, 2017 Member Report Share Posted February 2, 2017 nope, always reassign. It looks like a bug to me, its kinda laggy when I change tools. Also If I hold the button down, its stays on that tool, let it go and it goes back. But after deleting all the 3dcoat folders it runs perfectly again. Im not sure If its necessary to delete all the folders or only the latest ver. Quote Link to comment Share on other sites More sharing options...
New Member dimitrineron Posted July 2, 2017 New Member Report Share Posted July 2, 2017 I have the same problem, sometime the problem fix itself, when i change the tool by the menu. Quote Link to comment Share on other sites More sharing options...
Member ostapblender Posted August 2, 2017 Member Report Share Posted August 2, 2017 (edited) Yeah, I have the same problem on a 3D-Coat-V4.7.24X(64) build, in GL and DX mode. Sometimes it works, sometimes it's acting like this, idk what causes this and what pattern is. Here is screen capture of this behavior: As you can see, it's choosing desired tool and clicking back to current, but if you click to it with mouse - everything works fine. Pose tool assigned to ALT+E, trasform to ALT+R and Cut off to SHIFT+T. It seems only voxel tools are affected, because even if I choose surface tool on this mesh - shortcut works and it activates in a moment, without delay, unlike voxel tool, as you can see in video. Other voxel-related shortcuts seems to work OK. I'm also attaching scene file, maybe you can see something in it. UPD: oh, .24 is very old, there is .35 fashionable nowadays. Yeah, with update problem disappeared, at least for now. Shortcutslag.rar Edited August 2, 2017 by ostapblender Quote Link to comment Share on other sites More sharing options...
Member black_otter Posted September 14, 2017 Member Report Share Posted September 14, 2017 Same issue here. Any suggestions how to fix it without reinstalling Coat? Quote Link to comment Share on other sites More sharing options...
Member drate Posted September 14, 2017 Member Report Share Posted September 14, 2017 Hi guys, I also have the same problem. Has anybody found a solution for it? It suddenly appeared and occurs in different versions (4.7.36, 29, 06), stable and unstable. The only thing, that I recently changed on my system, was installing a Flash player update. Maybe it is related to this? As I daily use Coat in production, I highly depend on it and reinstalling it everytime would be not a good workaround. Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 14, 2017 Report Share Posted September 14, 2017 Do you have assigned any stack key combination ? Quote Link to comment Share on other sites More sharing options...
Member drate Posted September 14, 2017 Member Report Share Posted September 14, 2017 Yes, but even without them, the problem occurs. Also changing the shortcuts didn't work out. I also noticed, that the buttons on the left navigation lag as well, when clicked. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 14, 2017 Report Share Posted September 14, 2017 Are you using latest version 4.8 ? If yes, please contact for this issue Andrew Shpagin at support@3dcoat.com Thx Quote Link to comment Share on other sites More sharing options...
Member drate Posted September 15, 2017 Member Report Share Posted September 15, 2017 To 99% I believe, that I found the reason, after several uninstallations and testing different versions. I had installed the "3DC_brushes" pack from the website. After deleting it, the problem was not there anymore. Since then, everything works out great. Still testing though. @ Carlosan Thanks for the support. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted September 30, 2017 Advanced Member Report Share Posted September 30, 2017 any solution to this yet? I get the same problem, using 4.081. I dont have the 3DC_brushes pack, 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 30, 2017 Report Share Posted September 30, 2017 On 2/13/2015 at 11:55 PM, coverman said: I was having the same problem. I read help manual and it is written like this. Sticky keys does not work with Stacked Keys. So I export my hotkeys from [Edit] - [save hotkeys]. Open it with text editor, replace all <AllowStack>true</AllowStack> to <AllowStack>false</AllowStack> And reimport. I was released from that problem. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted October 10, 2017 Advanced Member Report Share Posted October 10, 2017 thanks I will try this! 1 Quote Link to comment Share on other sites More sharing options...
Member marou_666 Posted October 22, 2017 Member Report Share Posted October 22, 2017 On 30.09.2017 at 2:48 PM, Carlosan said: I was having the same problem. I read help manual and it is written like this. Sticky keys does not work with Stacked Keys. So I export my hotkeys from [Edit] - [save hotkeys]. Open it with text editor, replace all <AllowStack>false</AllowStack> to <AllowStack>true</AllowStack> And reimport. I was released from that problem. I tried this, problem still persists.... Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted October 25, 2017 Advanced Member Report Share Posted October 25, 2017 i uninstalled, deleted the folder, reinstalled, copied all my preferences back over, and so far the issue has not come back. drastic, but it works for now. I hope they get this bug sorted out. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted November 3, 2019 Advanced Member Report Share Posted November 3, 2019 november 2019 and this bug is still here. Version 4.9.07 - Please fix! 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 3, 2019 Report Share Posted November 3, 2019 Reported again. Sorry the delay. Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted June 24, 2020 Advanced Member Report Share Posted June 24, 2020 this issue is back in 4.9.51 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 27, 2020 Report Share Posted June 27, 2020 Bug reported. Thx for point it up. Quote Link to comment Share on other sites More sharing options...
New Member TZA Posted February 3, 2022 New Member Report Share Posted February 3, 2022 Its back! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 3, 2022 Report Share Posted February 3, 2022 If a hotkey is already assigned you will be asked if you wish to stack the tool/function with any previous tools/functions, allowing you to cycle between all of the tools with one hotkey. It is not this option ? Quote Link to comment Share on other sites More sharing options...
Member Jones C Posted February 20 Member Report Share Posted February 20 (edited) I just realised the same issue in version 2023. 1. In customize navigation, i set S + LMB to adjust brush radius and depth. This part work flawlessly. 2. I choose the Draw brush, hit End, assign hotkey to it, Alt + S. 3. Lets use Draw brush and Clay brush to illustrate the situation. Lets say i use Clay brush, then i switch to Draw brush by pressing Alt+S, if i change the brush size or depth by S+LMB, the moment i let go of key, it jump back to Clay brush. 4. If i did not change brush radius size or depth, it does not jump to Clay brush. 5. If i assign hot key Alt+A to Draw brush, changing brush size or depth does not jump to Clay brush. I am suspecting Alt + S is conflicting with S + LMB. It turn Alt + S to sticky key that once i let go of S key, it jump back to Clay brush, or any brush before i press Alt + S ** no stack key is used. Edited February 20 by Jones C Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 20 Report Share Posted February 20 Do you have sticky keys activated ? Not sure if it fits your working method or not, but it should work if you just tap the key/keys rather than hold them down. Tapping should switch to that tool until you want to change to something else. Quote Link to comment Share on other sites More sharing options...
