Member SebastianLeon Posted June 2, 2016 Member Report Share Posted June 2, 2016 Hi guys, I've been using 3d-coat for a while now and I've come to learn alot about how it works and figured out most of the issues I've encountered. Now the only issue I've got left is that whenever I change tools from Grow to Cut or Transform or any other tool, I get a 4 or 5 second delay and it's really disruptive to my workflow. I was wondering if anyone knew how to fix it? I'm using space bar (quick change menu) to swap tools. The only solution I've come up with so far is deleting my documents folder (the 3D-Coat folder) and re-entering my serial key. Please help! (I've also tried about 50 different client versions.. so that's really not the issue here) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 2, 2016 Report Share Posted June 2, 2016 Hi You perform a test using the last version 4.5.40 and have a tool change lag when open a new fresh project ? Quote Link to comment Share on other sites More sharing options...
Member SebastianLeon Posted June 2, 2016 Author Member Report Share Posted June 2, 2016 I just did a fresh install of the latest version and I still get the 3-5 second lag whenever I change tools :(. Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted June 4, 2016 Contributor Report Share Posted June 4, 2016 It's a notorious bug. First back up, and then remove %USERPROFILE%\Documents\3D-CoatV45\ToolsPresets directory and see if it helps. Restore the directory if it doesn't. Quote Link to comment Share on other sites More sharing options...
Member SebastianLeon Posted July 4, 2016 Author Member Report Share Posted July 4, 2016 On 6/4/2016 at 2:02 AM, ajz3d said: It's a notorious bug. First back up, and then remove %USERPROFILE%\Documents\3D-CoatV45\ToolsPresets directory and see if it helps. Restore the directory if it doesn't. I did do that and it worked for about a week. But now the lag is back and I tried to repeat what you suggested and it's not working :(. I wonder what could be causing this issue for my 3DCoat. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 9, 2017 Report Share Posted March 9, 2017 10 hours ago, Andrew Shpagin said: This is fixed in 4.7.25 - Quote Link to comment Share on other sites More sharing options...
