Member ghostweeble Posted June 4, 2016 Member Report Share Posted June 4, 2016 Hi all! I'm trying to map Lock Transparency under Layer Blending to a hotkey, so I can toggle it on and off. For some reason the hotkey doesn't seem to 'stick'. Once I select a different layer, the hotkey disappears. Is this a bug? Is there some other place that I can assign a hotkey to Lock/Unlock Transparency globally? Thanks! mm Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 4, 2016 Report Share Posted June 4, 2016 Bartalon I found a relatively easy way to re-bind this specific tool without using any third-party software (aside from Notepad)! Here's a list of steps with visual aid: As for step 3, considering the length of the hotkeys file, it will be easiest searching for old hotkeys doing a search of your letter between the >< characters. So, do a Ctrl F on >L< and it should take you right to any hotkeys related to L (or whichever letter you chose). 1 Quote Link to comment Share on other sites More sharing options...
Member ghostweeble Posted June 4, 2016 Author Member Report Share Posted June 4, 2016 (edited) Hi Carlosan, Thanks for your reply, but I'm a little confused. I already have Pick_Color remapped to "C", which works fine. What I'm trying to assign is Lock Transparency. I've exported and opened up the keyset file and I can see that my hotkey seems to be showing up as: </OneHotKey> <OneHotKey> <ID>OneLayerInfo::LockTransparency[1]</ID> <Code>T</Code> <Ctrl>false</Ctrl> <Alt>true</Alt> <Shift>false</Shift> <AllowStack>false</AllowStack> <UserDefined>1</UserDefined> </OneHotKey> It just doesn't seem to work correctly. I don't want it to lock transparency for just this layer, I want to be able to toggle the lock transparency box for the layer I've selected. Have I misunderstood your message? Thanks! mm Edited June 4, 2016 by ghostweeble Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2016 Report Share Posted June 5, 2016 You right, the example was about change pick color. I was trying the same key config, It just doesn't seem to work correctly after a program restart. I mailed support about this issue. <OneHotKey> <ID>OneLayerInfo::LockTransparency[1]</ID> <Code>T</Code> <Ctrl>false</Ctrl> <Alt>false</Alt> <Shift>true</Shift> <AllowStack>false</AllowStack> <UserDefined>1</UserDefined> </OneHotKey> </ClassArray.OneHotKey> Quote Link to comment Share on other sites More sharing options...
