Just a short question someone can answer me:
Did someone asked for a feature request to save used smart materials within scenes?
I know smart materials are saved in the user folder currently. But if you share your scene with someone, then you have to export the smart materials as a 3bpack seperately.
But what do you do, if you change your pc load the 3b backup scene and do not have any chance to get access to the workstation where you have created the origin scene? You have lost your smart materials then...
So you know what I mean? This is something really important and another reason for the upcoming dynamic smart materials features.
4 hours ago, Carlosan said:
Exactly. Something like this.
I know this kind of project organisation from softimage or Maya. The solution is good. So why not port it to 3D Coat?
Thank you Carlos
On 6/25/2017 at 0:16 PM, SERGYI said:
Currently working on Linux build. By the way, will it be ok if the new build will require latest Linux Ubuntu (particularly 16 and above)? What Linux distros do you have? Please report me directly on my e-mail "support DOT linux AT 3dcoat DOT com".
Hello. Any progress on that build?
T.
Hey, guys! Had some spare time and I "remastered" the splash screen picture. Hope, you'll like it.
I've zipped the splash screen images, you can replace (backup original) files at C:\Program Files\3D-Coat-V4.7.x\Splash\ folder.
Splash.zip
  • Like 3
I found a strange bug in 4.7.34. With the retopo Split Rings tool it very often makes two splits right next to each other. so close together that you almost can't see the row of polys between them. The only way I noticed is that some of the points get merged, creating a triangle so I saw them when I was trying to clean up triangles from my mesh.
Video:"
On 7/3/2017 at 4:47 AM, Carlosan said:
Can see the nodes, but the fill is noisy
I'm getting the same bug with the noise, when attempting to fill by layer or surface material.
I'm also still not seeing the nodes in build 4.7.32. I did a fresh install and everything. I go right back to build 4.7.31, and I can see the nodes.
One question to attached smart materials:
How do I change a smart material AT ONCE that is attached to multiple layers please? I mean the changes have to be refreshed in all attached layers simultanous.
I did not found something like this. Is this feature still in development?
Whitch advantages do I have currently with the new system? At the moment it is a advanced refill mode with a thumbnail in the layer and the possibility to edit the attached smart material (but only local). The real important advantages from linked materials are still missing.
Or do I overlook something?
If this topic was already discussed, then I missed it. So can you tell me the result of the discussion and when we will get real linked smart materials?
I don't know if someone already wrote a small concept for a better smart material system. So I try to do it here. In my opinion it is really easy to understand. Of course I do not know how hard the follwing features are to code. But anyway.
Advanced smart material concept ideas by Christoph:
What is a LINKED smart material in 3D Coat in the future?
You can link a smart material to one or more layers. This means you click with the RMB on a smart material within your smart material library and set this material to an active paint layer. You can link one material to as many layers as you want. What happens then?
a ) If you change the origin linked material in the library, then ALL linked layers gets the new smart material values and refreshes immediately.
b ) If you change a linked material locally (by clicking the RMB layer menu) then the same happen like in step a: all linked layers and the origin material in the library refreshes.
And why this? Because they are ALL "linked". They are all using the same informations. It is logic isn't it?
What is an ATTACHED/LOCAL smart material in 3D Coat?
I like the idea to convert a linked smart material to "local" or attach it to an individual layer to use it there only. I like the word "local" in this case more then attached.
So what does an attached or local material mean?
a ) You can attach a material to one or multiple layers one by one. But every layer with an ATTACHED material became idividual.
You can change individual smart material values, but only the layer where the material is attached refreshes.
No changes in other layers.
No changes in the main library.
Just local changes.
Example:
You have an attached red material in layer A and layer B. Both has the same attached material. But if you change one of them, only the changed layer gets the new values. The other one stays. This is the current model we have in 3D Coat.
Result
We should have three kind of paint layer situations in the future:
1 ) A layer with an linked smart material: One or more layers has linked materials. All this layer content changes, as soon as we change the linked smart material. By using the layer menu or by changing it in the main library.
2 ) A layer with an local/attached layer: One or more layers has attached materials. Every material is individual. You can change them locally. Even the origin material in the library will not refresh if you change a layer whitch was attached with it. Every information ist local. A small icon inside the material thumbnail in the layer could mark a local layer material.
3 ) A combi layer (default). What is a combi layer?
A combi layer is a combination of different paint informations. You have painted with several smart materials or just colors within this single layer. There is no specific linking or attachment to a single material because you used multiple painting informations and colors. So 3D Coat do not know (yet) what part in the layer have to be refreshed. But if you link or attach a new material to a combi layer, all information will be replaced by the new material. And you have a situation like point 1 or 2 above.
So. What is the problem to understand this? It would serve nearly all needs, right?
Thank you for your time
Chris
PS: Maybe in the future Andrew will develop a way to link to locally painted strokes. So we can maybe refresh a painted area of a single layer. But this is science fiction for now...
  • Like 4
I just noticed that 4.7.33 is posted at the beta download section... No notice here about the new beta version so curious as to what this version brings to the table or bug fixes. Thanks.
Edited by digman
Did I miss an announcement -- been away for a while.  4.7.33 build doesn't have cuda support?
4.7.34 [beta]
- square alphas complete support, even older ones will act correctly.
- possibility to change font size in Preferences->Theme. 4K monitors support. Font will be automatically changed to big size on large resolution.
- "File->Import multiple objects" to import multiple objects in diferent ways.
- Fixed memory leaks during materuals to layers attaching
- Checkbox in Underccuts/bas relief to limit effect below the plane.
- Import AO with channel picking
- Problem of laggy rotation of symmetry plane in General mode fixed. Picking point 2 is also fixed.
- Select all in tweak room
- Possibility to switch between 2 modes during navigation - around Y and free rotation. See navigation panel.
I think it should be stable build, but need approving.
  • Like 5
I've just tested it, and I still got the issue on full layer fill in gradient mode depicted by Carlosan and I. The issue on the default TilePlane's curvature/AO bake are still here too.
But as I guess we're not enough users working with the tileplane intensively, just the gradient issue should be fixed ( btw I may find a workarround to generate my curvature/AO on external software )
Edited by Vexod14
Yes, fill entire layer in gradient mode is noisy
Also, looks like when Font Size is set to Auto or Medium it's too big on 1920x1200, but when it's set to Small - it's too small or unclear, kind of distorted font:
Oh, new rotation mode is awesome! Thanks alot!
Edited by druh0o
V 4.7.34: Render room seems to be buggy. Made a quick test with a default sphere (Per pixel mode).
3DC render does not stop when Realtime Render is on. After switching off, there are artefacts on the sphere.
Can confirm render room leaves artifacts on my models. Leaving the room and coming back does not fix it either. Also the default 3D-Coat renderer is still missing the custom render size options. It has been this was at least since .32
Edit: I don't seem to see the "File->Import multiple objects" option either. I just see the regular import objects selection.
Edited by Mystical
Any progress on the Linux builds?
I can understand that things take time, but checking every so often here just to see if there's a build it's getting tiresome. And then, one could miss the long awaited build if sayed out for months. So knowing if something is moving would be appreciated.
It's a pity Linux uses can't test as much or get new beta tools to tinker with. It feels like there's no proper system in place to adapt and compile Linux builds, as if there was some sort of part-time off-site job. It doesn't look as a priority for sure to keep all versions on par.
I can understand that while trying new tools, and refining them, having to re-compile over and over again for a different platform would seem a waste of time. But we also pay for the license, and one would think that end users won't find that a waste at all. Not to mention the possibility of some Linux specific bugs appearing so much later; that would amount to even more wasted time (for the users mainly). Surely there could be a compromise in the "waste" of developers vs users' time.
I'm trying to make a point to justify my question, but not to sound harsh or impatient. I hope I didn't fail completely. :-)
Edited by Allabulle
The build 4.7.34 for Linux will be uploaded in the nearest days.
Great!
Thanks for taking the time to answer here. I know things are hard and look simpler from afar.
I'll check back in a few days.
If there's something we can do to ease the process feel free to ask.
Thanks again.
Edited by Allabulle
Nice update ! It seems that the gradient works damn faster now =D
Another issue I guess you've seen, is when you paint with some smartmaterials, attached on your layer, stroke over stroke does not work fine. But it depends on which material you use. For example I tried with the pink plastic one ( default profided into plastic's folder ) and I didn't get any issue.
Another one, on the tileplane this time. When you bake a curvature it goes full white, which is not accurate as long as the plane is not a sharp edge itself, I expected the curvature to be a "neutral grey". The issue that it leads to is that you can no longer use any smartmaterials properly on the tileplane until you've get your curvature good. I know it's not that useful and does not happen often ( honnestly I would never do that but it was someone at work who asked why it doesn't work as he expected ^^" I would'nt blame you guys if you do not plan to fix it ^^ )
And last thing, is a feature that allows to "bake" a smartmaterial on tileable PBR maps qith somthing like the export constructor ( if not that one cause it's just a perfect tool ), it might be tricky I guess. The point is that sometimes you get some good feeling on a smartmaterial but with way too much tweaks, layers and maps into it, and you can't extract what you've done to take it into, for example unreal or unity to roughly texture some environment assets. ( If that's already possible please let me know =) )
