Advanced Member Vipera Posted September 9, 2016 Advanced Member Share Posted September 9, 2016 Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139765 Share on other sites More sharing options...
Contributor Tony Nemo Posted September 9, 2016 Contributor Share Posted September 9, 2016 Click the "Subdivide" button as many times as you need to smooth the OBJ. Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139767 Share on other sites More sharing options...
Advanced Member Vipera Posted September 10, 2016 Advanced Member Share Posted September 10, 2016 3 hours ago, Tony Nemo said: Click the "Subdivide" button as many times as you need to smooth the OBJ. Thank you for advice! Another question about retopology mesh. Why when I go to File->Import->Reference Mesh or New file->Perform Retopology->Import reference mesh I have nice smooth reference mesh with textures but if I go to Retopo room->Retopo->Import I have a mesh without textures and smooth groups. This is kind of annoying that program has so many duplicated commands and each of them work in a different way. Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139772 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 10, 2016 Reputable Contributor Share Posted September 10, 2016 4 hours ago, Vipera said: Thank you for advice! Another question about retopology mesh. Why when I go to File->Import->Reference Mesh or New file->Perform Retopology->Import reference mesh I have nice smooth reference mesh with textures but if I go to Retopo room->Retopo->Import I have a mesh without textures and smooth groups. This is kind of annoying that program has so many duplicated commands and each of them work in a different way. This is because the Retopo Workspace isn't designed to work with textures or shaders. You import meshes or create ones from scratch there, for generating Retopo meshes. You could also consider it a place to bake a target mesh to which 3D Coat sends a baked copy to the Paint Workspace. REFERENCE MESH is an old, legacy option from the V2 days. Send your dense models directly to the Sculpt room. 1 Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139778 Share on other sites More sharing options...
Advanced Member ghib Posted September 13, 2016 Advanced Member Share Posted September 13, 2016 For me in version 4.7.10 the Normalmap layer does NOT respect Clip Mask Layer options. Has this always been the case or just with this latest version. I've never actually tried to do any Clip Masking on the NormalMap layers before so I have no frame of reference. Too busy at the moment to install and try a different version. Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139854 Share on other sites More sharing options...
Carlosan Posted September 13, 2016 Share Posted September 13, 2016 ghib I use this settings for that task. I found it resolved. Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139856 Share on other sites More sharing options...
Javis Posted September 13, 2016 Share Posted September 13, 2016 2 hours ago, ghib said: For me in version 4.7.10 the Normalmap layer does NOT respect Clip Mask Layer options. Has this always been the case or just with this latest version. I've never actually tried to do any Clip Masking on the NormalMap layers before so I have no frame of reference. Too busy at the moment to install and try a different version. I don't know about imported normals, I haven't done that in a while, it did used to work if it's not working now. But for newly created depth layers, it does work for me in 4.7.10 on windoze. I'm using the feature on a project right now, and just in case, I tested in a new scene. It's working without a hitch over here. Just to be sure, are you using the color channel to mask depth? Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139860 Share on other sites More sharing options...
Advanced Member ghib Posted September 14, 2016 Advanced Member Share Posted September 14, 2016 Thanks for the responses guys. @Carlosan that doesn't work with Imported NormalMaps unfortunately. This is very much linked to an earlier post I made where I was requesting the ability to paint depth in an Opaque manner above an imported Normal Map Layer. Currently it doesn't work. @Javis, yes with Imported NormalMaps the clip masking doesn't work. So you managed to mask a NormalMap layer using a Layer with an RGB Layer? I believe that possibly Andrew needs to have a look at the functionality of using Imported NormalMaps and painting Depth in 3dCoat. Currently they feel a little disconnected. p.s. this has nothing to do with Masking depth painted on a layer in 3DCoat. Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139872 Share on other sites More sharing options...
Advanced Member Boonta Posted September 15, 2016 Advanced Member Share Posted September 15, 2016 (edited) Bug in 4.7.10: - Flat shade mode seems to be displaying specular/metalness information instead of just albedo. I am using the roughness/metalness workflow. - areas designated as metalness in flat shade mode show up as much brighter and colorpicking them does not sample the lighter color as seen in the viewport but rather a color much darker. - switching from flat shade mode to specular color mode seems to display the correctly painted colors without a lighter filter over the top as seen in flat shade mode? - In line with the above, painting roughness on a layer adds a mid grey to spec color.. is this normal behavior? Selecting a layer.. turning off all paint able channels except spec/roughness and hitting delete willl return the spec color channel to black. Is this channel meant to be black in a roughness/metalness workflow? or the mid grey? - it appears that the brightening of metalness areas in flat shade mode isnt happening in 4.5.40. Edited September 16, 2016 by Boonta Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139896 Share on other sites More sharing options...
Advanced Member Boonta Posted September 16, 2016 Advanced Member Share Posted September 16, 2016 (edited) Further testing: The following relates to what is seen when going to view > spec color mode, and view > flat shade mode (under glossyness/metalness workflow) using the "preview sphere" (and turning off the ambientocclusion layer that it opens with) Metalness is ZERO in all these cases. 4.5.39 spec color shows up as grey 23% painting a blue stroke (zero roughness, zero metalness) of 0,0,255 shows up as 0,0,255 under flat shade mode spec color remains as grey 23% as strokes are painted on it that also contain a roughness value. (behavior is different in 4.7.10) 4.7.10 spec color shows up as black. painting on the sphere with any value of roughness will now add 23% grey to the spec color. blue stroke painted 0,0,255 shows up as 58,58,255 under flat shade mode!!! deleting spec/roughness values from this layer will return the color back to the apropriate 0,0,255. when viewing in flat shade mode. Deleting this information also makes the "spec color" go to black. It seems somehow this spec color is effecting what is seen in the flat shade mode. I am expecting when entering flat shade mode to essentially see albedo only. If for whatever reason other data is showing, can we get a view mode to show albedo only or fix flat shade mode. Edited September 16, 2016 by Boonta Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139898 Share on other sites More sharing options...
mifth Posted September 16, 2016 Share Posted September 16, 2016 19 hours ago, Boonta said: Further testing: The following relates to what is seen when going to view > spec color mode, and view > flat shade mode (under glossyness/metalness workflow) using the "preview sphere" (and turning off the ambientocclusion layer that it opens with) Metalness is ZERO in all these cases. 4.5.39 spec color shows up as grey 23% painting a blue stroke (zero roughness, zero metalness) of 0,0,255 shows up as 0,0,255 under flat shade mode spec color remains as grey 23% as strokes are painted on it that also contain a roughness value. (behavior is different in 4.7.10) 4.7.10 spec color shows up as black. painting on the sphere with any value of roughness will now add 23% grey to the spec color. blue stroke painted 0,0,255 shows up as 58,58,255 under flat shade mode!!! deleting spec/roughness values from this layer will return the color back to the apropriate 0,0,255. when viewing in flat shade mode. Deleting this information also makes the "spec color" go to black. It seems somehow this spec color is effecting what is seen in the flat shade mode. I am expecting when entering flat shade mode to essentially see albedo only. If for whatever reason other data is showing, can we get a view mode to show albedo only or fix flat shade mode. I can cofirm that Flat shading with specular is broken at 4.7.x. Reported it here http://3dcoat.com/mantis/view.php?id=2189 Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139918 Share on other sites More sharing options...
Advanced Member Boonta Posted September 16, 2016 Advanced Member Share Posted September 16, 2016 (edited) thanks for confirming that! - I had to just restart 4.7.10 due to the undo stack no longer recording more than 1 action. strange bug not sure if i can reproduce... will monitor it some more. - rotate around last draw point seems to randomly reset its self at times as well. Edited September 16, 2016 by Boonta Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139919 Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 19, 2016 Contributor Share Posted September 19, 2016 On paint room each time we open 3D Coat the opacity value is different. Sometimes 60 , 90 , 93 etc etc Just painted a hard asset with 93 opacity and now i must re do it. Can we please fix the value to be always 100%? Thank you in advance Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139940 Share on other sites More sharing options...
Advanced Member Tarby Posted September 19, 2016 Advanced Member Share Posted September 19, 2016 Beta 4.7.10 - imported normal maps are a mess. The only way to limit them is to manually erase them with a brush which takes forever. Using freeze to erase areas of the normalmap layer corrupts their edges with blocky nonsense, and there may as well be no option to mask them using another layer as it has no effect at all. Could you please at least address that last as a workaround for now? Cheers. Win7 64 (Thanks to Carlosan) Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139956 Share on other sites More sharing options...
Advanced Member Boonta Posted September 19, 2016 Advanced Member Share Posted September 19, 2016 (edited) id love to see some performance improvements on the texture adjustment operations. they are pretty slow when working with many layers and prb materials. more advanced even non destructive adjustments aka Photoshop/substance would be cool to see. i.e. to preview a change when perfoming a RGB adjustment on a layer atm in my document takes a full couple of seconds to change just one channel i.e. red from 100 to say 120 value. also is there any planned updates for using an IDmap in paintroom to aid in masking? Edited September 19, 2016 by Boonta 1 Link to comment https://3dcoat.com/forum/index.php?/topic/19525-3dcoat-47-beta-testing-thread/page/13/#findComment-139964 Share on other sites More sharing options...
