Andrew Shpagin Posted August 30, 2016 Author Share Posted August 30, 2016 4.7.10 (stable) - Unify UV command to drop all faces to the current UV set - "Editt points" in Lathe tool shows coordinates in more logical way. - Correct stencil mapping and preview, there was problems with object scale and preview - Warning shown if texture in smart material missing - Correct preview for stencil/materials in navigation mode for cylinder/sphere mapping. - Correct UnhideAll command in UV/retopo room (was not working in Mark Seams mode) - Cone primitive got "USe sector" option compatible with bevel. - correct Ptex export with LWO files using Export menu. - Seed value for smart material noise 4 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 30, 2016 Author Share Posted August 30, 2016 On 20.08.2016 at 4:22 AM, Cleitus said: Прошу прощения, что пишу на Русском. Хочу описать проблемы с которыми я сталкивался. 1 Это проблема с качеством карты нормалей на ровных местах при bake. 2 При перезапуске сцены на воксельных слоях появляются деревянные признаки и при сглаживании они становятся жоще 3 Проблема при bake сцены с оптимизированными surface слоями, появляются такие признаки This is fundamental problem that generally may be solved using 16 bit normalmaps. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 30, 2016 Author Share Posted August 30, 2016 On 18.08.2016 at 4:11 PM, ghib said: Hi Andrew, 2 things. Could you please check your code for Editing All Layers in Ext Editor please. (and other Send functions.) I'm experiencing a bit of a deal breaking bug where Saving the Layers.PSD from Photoshop after editing back to 3DCoat. Once back in 3DC the Layers won't always be in the same order, and sometimes groups will become children of other groups You might need to add the layer blending mode 'Pass Through' to better match what Photoshop has. Currently this is the only blending mode that Photoshop has that 3DCoat doesn't. *Edit1* Just tried again after cleaning up the layer and groups in my scene and sent to Photoshop which gave the error message 'Some groups were found corrupted and repaired.' In the Layers.psd file it has parented a Layer group under another group and also one of the layers has been renamed <end> thanks. It is generally useless to check because code is very complex. But if you have scene where order is not kept or other problems happening - please send it to support, it will help to solve the problem. Link to comment Share on other sites More sharing options...
Taros Posted August 30, 2016 Share Posted August 30, 2016 1 hour ago, Andrew Shpagin said: 4.7.10 (stable) - Unify UV command to drop all faces to the current UV set - "Editt points" in Lathe tool shows coordinates in more logical way. - Correct stencil mapping and preview, there was problems with object scale and preview - Warning shown if texture in smart material missing - Correct preview for stencil/materials in navigation mode for cylinder/sphere mapping. - Correct UnhideAll command in UV/retopo room (was not working in Mark Seams mode) - Cone primitive got "USe sector" option compatible with bevel. - correct Ptex export with LWO files using Export menu. - Seed value for smart material noise Where is the seed value for noise placed? I don't find the option. Thank you Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted August 30, 2016 Contributor Share Posted August 30, 2016 Huge thanks for unify uv command. Sent from my Turbo-X_epsilon using Tapatalk Link to comment Share on other sites More sharing options...
Advanced Member Vipera Posted August 31, 2016 Advanced Member Share Posted August 31, 2016 (edited) I still would like to have all smart materials pictures (new or modified) to be saved with one standard lighting instead of current scene lighting. It is impossible to compare them with the current settings when their preview depends on the scene scene lighting. Edited August 31, 2016 by Vipera 4 Link to comment Share on other sites More sharing options...
Advanced Member Vipera Posted August 31, 2016 Advanced Member Share Posted August 31, 2016 When I was installing version 4.7.10 splash screen at the beginning of installation showed version 4.5. Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 1, 2016 Contributor Share Posted September 1, 2016 Paint room on export progress bar no longer exist!!! Link to comment Share on other sites More sharing options...
Advanced Member dimitribastos Posted September 1, 2016 Advanced Member Share Posted September 1, 2016 (edited) On 30/08/2016 at 1:32 AM, Andrew Shpagin said: 4.7.10 (stable) - Unify UV command to drop all faces to the current UV set - "Editt points" in Lathe tool shows coordinates in more logical way. - Correct stencil mapping and preview, there was problems with object scale and preview - Warning shown if texture in smart material missing - Correct preview for stencil/materials in navigation mode for cylinder/sphere mapping. - Correct UnhideAll command in UV/retopo room (was not working in Mark Seams mode) - Cone primitive got "USe sector" option compatible with bevel. - correct Ptex export with LWO files using Export menu. - Seed value for smart material noise Would be great to have some diferentt noises as well. Also, what about some default noises to use on the masks of smart material editor? Thanks! Edited September 1, 2016 by dimitribastos Link to comment Share on other sites More sharing options...
Carlosan Posted September 1, 2016 Share Posted September 1, 2016 Please feel free to add a +1 Please add (Open Source) Bercon Maps Procedural painting and procedural texture editor To use procedural maps to make alphas -eXbrushes- Vector Texture Maps Link to comment Share on other sites More sharing options...
Javis Posted September 1, 2016 Share Posted September 1, 2016 It would be really great if we could get poly groups/selection sets so we could perform those kinds of noise operations more easily on specific areas would be in order, too. I mean having noises is great, but but applying them easily is essential. Perhaps selection sets from the LWO format would work, that way at least you can import selection sets and not necessarily program to whole set of tools to create them in 3DC. I digress however, right now Andrew is focused on a few other things: Layer Masks, Brush Improvements and UV Improvements, such as proper multi-tile I/O, UDIMs, etc.. So if you guys have ideas for those areas, get those ideas flowing in this thread. I'm sure Andrew will be reading your thoughts. 1 Link to comment Share on other sites More sharing options...
Javis Posted September 1, 2016 Share Posted September 1, 2016 Here's an example of what I mean: 1 Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 2, 2016 Contributor Share Posted September 2, 2016 Issue with Layer 0 on paint room. I want to get transparency so i erase parts of my model on layer 0. I save and close. When i re open the scene Layer 0 is there in full!!!. Happens with any 3d model , even a autopo cube . Latest versions on DX same happens on GL too. Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted September 2, 2016 Advanced Member Share Posted September 2, 2016 Move points to nearest point in the lathe tool will not delete...is there a trick to this. This has not worked for me for a while. Anybody else? Link to comment Share on other sites More sharing options...
Carlosan Posted September 2, 2016 Share Posted September 2, 2016 0001501: Converts existing model into a set of separate surfaces (panels) with thickness. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 2, 2016 Reputable Contributor Share Posted September 2, 2016 On 9/1/2016 at 5:27 AM, dimitribastos said: Would be great to have some diferentt noises as well. Also, what about some default noises to use on the masks of smart material editor? Thanks! 9 hours ago, Carlosan said: 0001501: Converts existing model into a set of separate surfaces (panels) with thickness. I've been trying to get Andrew to do this for a few years, now. Nothing has ever come of it. Could be helpful for ALL users, not just a few. 1 Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 2, 2016 Reputable Contributor Share Posted September 2, 2016 13 hours ago, Michaelgdrs said: Issue with Layer 0 on paint room. I want to get transparency so i erase parts of my model on layer 0. I save and close. When i re open the scene Layer 0 is there in full!!!. Happens with any 3d model , even a autopo cube . Latest versions on DX same happens on GL too. Andrew really needs to rework transparency in the Paint Room. It's the one aspect that is NOT PBR. It's terrible. At least the PBR shaders give a decent proximity. Impossible in the Paint room. This is why PBR shaders should work on Paint Meshes as well. 1 Link to comment Share on other sites More sharing options...
philnolan3d Posted September 2, 2016 Share Posted September 2, 2016 On 6/27/2016 at 0:00 AM, AbnRanger said: Anybody else having issues with 3D Coat crashing when you've left it open/running > take a break and come back to it (clicking on the minimized instance)? It's happened to me at least 4-5 times this past week, regardless of what scene I had opened. Yes, this has happened a lot to me. I sent in 3 crash reports I think. I also noticed the app and the crash reports have the wrong version number so I wrote in the correct one. 1 Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 2, 2016 Reputable Contributor Share Posted September 2, 2016 I also notice, quite frequently, that a big block of Pixels shift arbitrarily, when I'm sculpting. Happens at least a few times a sculpting session. UNDO also gets borked often, right after an Auto-Save. So, if you need to go back several steps right as Auto-Save stops your work, many times you cannot go back. It's as if 3D Coat flushes UNDO with most every Auto-Save...or it seems that way. 1 Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted September 4, 2016 Advanced Member Share Posted September 4, 2016 On 9/3/2016 at 4:57 AM, AbnRanger said: Andrew really needs to rework transparency in the Paint Room. It's the one aspect that is NOT PBR. It's terrible. At least the PBR shaders give a decent proximity. Impossible in the Paint room. This is why PBR shaders should work on Paint Meshes as well. About transparency, Andrew now added a new function to add black instead of gray for transparent areas. Its still better to make the output transparent. Modo supports transparent pngs. Link to comment Share on other sites More sharing options...
Taros Posted September 5, 2016 Share Posted September 5, 2016 On 2.9.2016 at 9:20 AM, Michaelgdrs said: Issue with Layer 0 on paint room. I want to get transparency so i erase parts of my model on layer 0. I save and close. When i re open the scene Layer 0 is there in full!!!. Happens with any 3d model , even a autopo cube . Latest versions on DX same happens on GL too. We have layer 0 problems too sometimes. Here layer 0 disappear sometimes, and there appear a CurvaturesMap layer instead of layer 0. Really strange. @Andrew: Any ideas. Unfortunatey we can not reproduce it. It appear when we work with retopo baking in first case. 1 Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 5, 2016 Contributor Share Posted September 5, 2016 Sometimes Layer 0 disappears as well. Great notice you did there. Couldnt find why this happens either. Link to comment Share on other sites More sharing options...
Taros Posted September 5, 2016 Share Posted September 5, 2016 On 2.9.2016 at 11:24 PM, philnolan3d said: Yes, this has happened a lot to me. I sent in 3 crash reports I think. I also noticed the app and the crash reports have the wrong version number so I wrote in the correct one. Updating the graphic card drivers help here in some situations too. 1 Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 5, 2016 Contributor Share Posted September 5, 2016 On latest drivers always , Don also warned me about Nvidia drivers doing strange things , some of them i noticed as well (crashes and restarts on several occations regarding 3D Coat , allthough Don also told me that he had the same or similar in other software as well. Link to comment Share on other sites More sharing options...
Taros Posted September 8, 2016 Share Posted September 8, 2016 On 2.9.2016 at 9:20 AM, Michaelgdrs said: Issue with Layer 0 on paint room. I want to get transparency so i erase parts of my model on layer 0. I save and close. When i re open the scene Layer 0 is there in full!!!. Happens with any 3d model , even a autopo cube . Latest versions on DX same happens on GL too. in my opinion the best advice here is to never use or paint anything on layer 0. For me it is a system layer and have not to be touched ever. What we do to get transparency is to hide layer 0 for the session. 2 Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 8, 2016 Contributor Share Posted September 8, 2016 If i erase parts only on other layers , Layer 0 interfiers on export. Must erase on Layer 0 and export to get the transparency right. At least on my end here. Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted September 8, 2016 Contributor Share Posted September 8, 2016 (edited) Instead of erasing layer 0 to get transparency, you can simply hide it. --- Ok, I just noticed Taros has already mentioned this. Edited September 8, 2016 by ajz3d 1 Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 8, 2016 Contributor Share Posted September 8, 2016 I end up hidding it ,most of the times Anyway , did anyone noticed issues on voxel scultping? Deforms badly the voxels , noticed it on move. Link to comment Share on other sites More sharing options...
Javis Posted September 9, 2016 Share Posted September 9, 2016 The issue I'm finding lately, is that even with layer 0 off, there is no transparency in the layer(s) that are exported. Sure, there's an alpha channel, but like geo_n and I have been harping on (and will forever do until the end of time, or until it's implemented), is that the alpha needs to be in the transparency channel, too. It's crucial really to dealing with lots of textures, lots of objects. Each time you need to create a new transparency channel, for each layer, and then paste the alpha channel into the transparency channel, check it to make sure it didn't leave any wacky edges and then save. It should just save the alpha into the trans channel, export from 3DC, done. 2 Link to comment Share on other sites More sharing options...
Advanced Member Vipera Posted September 9, 2016 Advanced Member Share Posted September 9, 2016 (edited) Is it possible to bring OBJ file for voxelization and keep smooth groups of geometry? When I use Import button in Sculpt room all geometry comes without smooth groups. Try to import a sample object cone, for example. Instead of smooth surface I have sharp angles. Edited September 9, 2016 by Vipera Link to comment Share on other sites More sharing options...
