Member AllinRisks Posted June 18, 2016 Member Report Share Posted June 18, 2016 Hi! The basic question is: Is there a way of clicking on the different retopo objects on the model it self to quickly select them or do I have to manually go and check by clicking on each retopo group until the right one is selected? ex. Alt click in Zbrush on a subtool selects the corresponding subtool. Thanks for the help! <3 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 19, 2016 Report Share Posted June 19, 2016 Was solved in version 4.7 (experimental build) - Clicking on faces from different UV set will select current UV set in retopo/uv room. - Other UV sets are shown in retopo room as well, you may operate over vertices/faces not only in current set/group but in other sets/grups as well. Quote Link to comment Share on other sites More sharing options...
Member AllinRisks Posted June 20, 2016 Author Member Report Share Posted June 20, 2016 Ah okey great! So its on its way? Superb!! Quote Link to comment Share on other sites More sharing options...
