Selecting Retopo Objects by clicking on mesh?
AllinRisks
Hi!
The basic question is: Is there a way of clicking on the different retopo objects on the model it self to quickly select them or do I have to manually go and check by clicking on each retopo group until the right one is selected? ex. Alt click in Zbrush on a subtool selects the corresponding subtool.
Thanks for the help! <3
Was solved in version 4.7 (experimental build)
- Clicking on faces from different UV set will select current UV set in retopo/uv room.
- Other UV sets are shown in retopo room as well, you may operate over vertices/faces not only in current set/group but in other sets/grups as well.
