Member Sketchup Posted June 20, 2016 Member Report Share Posted June 20, 2016 (edited) So when you choose the blend mode "Use as emissive" for a layer, will you actually be able to see the luminescence from within 3D coat? Or is this feature only seen after export? The white oval is the emissive portion. It was blue colored before I set it as emissive. Edited June 20, 2016 by Sketchup Quote Link to comment Share on other sites More sharing options...
Advanced Member Tarby Posted June 20, 2016 Advanced Member Report Share Posted June 20, 2016 (edited) Might be best to view it in the Render Room and reduce the environment brightness to check it (not overall exposure). Edited June 20, 2016 by Tarby Clarification Quote Link to comment Share on other sites More sharing options...
