Member jeric_synergy Posted June 20, 2016 Member Report Share Posted June 20, 2016 Doing the rat tutorial with the smallest voxel sphere, when I add the neck and use SMOOTH, it erases the 'snake' immediately, unless the 'Smoothing' parameter is dropped to 1%. Since it defaults to 100%, I'm wondering why it is so strong? And: is it possible to set a default? I'm almost sure I'll never use it at 100%, and I sure don't want to reset it every session. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 20, 2016 Contributor Report Share Posted June 20, 2016 Setting at a low value is remembered from tool to tool and from use to use. 1 Quote Link to comment Share on other sites More sharing options...
