Member Sketchup Posted June 21, 2016 Member Share Posted June 21, 2016 (edited) I need to scale down my model dramatically, and I have a ton of stray objects. Additionally some objects are inside of other objects, making them extremely difficult to select. Is there a way to "select all" in the tweak room, and if not, would it be possible to export an OBJ, scale it down in another program, and somehow reimport all of the textures? Edited June 21, 2016 by Sketchup Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 21, 2016 Share Posted June 21, 2016 1 Quote Link to comment Share on other sites More sharing options...
Member Sketchup Posted June 22, 2016 Author Member Share Posted June 22, 2016 Thanks, Carlo! The rectangle tool didn't work at all for me. I would drag it around the model but it would do nothing. The square tool would select geometry, but wouldn't select things that weren't visible to the camera. However the Replace Geometry thing is an awesome suggestion that I didn't know even existed. Thanks! I ended up exporting everything into Maya and performing my transformations there. Have a nice day! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 22, 2016 Share Posted June 22, 2016 You welcome, may be there is a bug with the rectangle selection. Can you please make a test ? Select model parts first using a brush, change to rectangle, pick outside the object and then drag and drop over the object using the rectangle. Only the objects selected first with the brush, can be selected later by the rectangle. Your confirmation will be very helpfull ty ! Quote Link to comment Share on other sites More sharing options...
