New Member Pixelbasher Posted July 20, 2016 New Member Report Share Posted July 20, 2016 Hi, Is there a way to save user files in another directory than c:\user\.... by default? Thank you in advance Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 20, 2016 Report Share Posted July 20, 2016 On the PC, there is a small arrow in the upper right corner of the Materials Popup. When clicked, it allows you to add folders of textures which will then be available to 3D coat. If you RMB an existing texture and choose 'Edit Material', you can see which files are included in the material. The folder(s) can be anywhere and you can use the same procedure for the current version and the Beta. Quote Link to comment Share on other sites More sharing options...
New Member Pixelbasher Posted July 21, 2016 Author New Member Report Share Posted July 21, 2016 Ah, ok. I also mean things like autosave and all that. C: gets a bit crowded on my machine. And Carlson, for what it is worth. I read so many posts and tips by you that I wanted to express my thanks for your dedication. Thank you. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 21, 2016 Report Share Posted July 21, 2016 you welcome the last version have a new installer, it let you select the default installation folder. Windows let you modify the default user/user files location, please take a look. BR ! How to Change the Default Location of User Folders in Windows 7 and Windows 8 Quote Link to comment Share on other sites More sharing options...
