[Solved] Top and bottom views: possible to redefine ?
David O'Neil
Just purchased 3D Coat after playing with the trial a couple days.  An issue for the engineer in me is that the views are terribly inconsistent. Is there a way to make the camera views show the proper perspective?  When you look at something from the front, and rotate it to look at the bottom, you don't also turn it 90 degrees left to right.  Blender gets this right.
I am guessing this was not fixed as top view gives you top right view , bottom left view.   right side view shows you the left side of model  . your in  right side viewing mode but it shows you the left side of your model . Why would I want to see the left side in right side view?  Then I say how does one say that's fine  its good enough . I just expect not except more from 3dc . A little tlc for the basic things.  Just some venting ... on with my day.
