Member viking Posted August 11, 2016 Member Share Posted August 11, 2016 HI,how to export normal map?and when i edite all layers in ext.edit(ps),why no normal map?it is empty. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/ Share on other sites More sharing options...
Carlosan Posted August 11, 2016 Share Posted August 11, 2016 Hi ! Are you using the last version 4.7.06 ? On Paint Room there is 2 ways File > Export objects and Textures or Textures > Export > Normal Map Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-138935 Share on other sites More sharing options...
Member viking Posted August 11, 2016 Author Member Share Posted August 11, 2016 thank you,but if i want to use ext.edit(ps) to edit normal maps,how to use it? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-138936 Share on other sites More sharing options...
Carlosan Posted August 11, 2016 Share Posted August 11, 2016 Do you have a normal map plugin in Photoshop ? Normals maps cant be edited as any raster graphics. Sorry I did not understand your workflow to help better. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-138943 Share on other sites More sharing options...
Member viking Posted August 12, 2016 Author Member Share Posted August 12, 2016 Yes, i have a normal map plugin in Photoshop. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-138964 Share on other sites More sharing options...
Carlosan Posted August 12, 2016 Share Posted August 12, 2016 Please try this Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-138969 Share on other sites More sharing options...
Member SpectrumZX Posted September 6, 2023 Member Share Posted September 6, 2023 On 8/12/2016 at 1:53 PM, Carlosan said: Please try this But then all layers are exported as one texture. Is it possible to export a normal map with all layers preserved? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-190180 Share on other sites More sharing options...
Carlosan Posted September 7, 2023 Share Posted September 7, 2023 Try editing all layers in external editor command. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-190192 Share on other sites More sharing options...
Member SpectrumZX Posted September 7, 2023 Member Share Posted September 7, 2023 11 hours ago, Carlosan said: Try editing all layers in external editor command. I open a project only with a color map, there are no normal maps by layers, like the rest of the channels too Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-190197 Share on other sites More sharing options...
Carlosan Posted September 7, 2023 Share Posted September 7, 2023 Sadly so you need to export one by one, sound as a good feature request Please drop a mail at support@3dcoat.com Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-190198 Share on other sites More sharing options...
Member SpectrumZX Posted September 8, 2023 Member Share Posted September 8, 2023 16 hours ago, Carlosan said: Sadly so you need to export one by one, sound as a good feature request Please drop a mail at support@3dcoat.com Okay, thanks very much! Quote Link to comment https://3dcoat.com/forum/index.php?/topic/19832-hihow-to-export-normal-mapand-when-i-edite-all-layers-in-exteditpswhy-ino-normal-map/#findComment-190202 Share on other sites More sharing options...
