Member Bloodsong Posted September 19, 2016 Member Report Share Posted September 19, 2016 Too Long Don't Read:================================================================== i was doodling around in my 4.5.19 DX 64 bit (the one that's been working best with my hardware/software/wetware) this morning, then thought, hey, i should download the latest version and see how much it has improved! i installed 4.5.38 in parallel (as usual), popped in a medium-res sphere, and did what i normally do: turn on x symmetry, use the grow tool to grow out a 'muzzle' and a 'skull,' then grab a huge move tool and yank things around to shape a monster head. and it is NOT what i am used to...! the move tool keeps tearing the voxels and leaving artifacts, crashing into other voxels, leaving some voxels behind... =================================================================================== so, image: TOP: 3D Coat 4.5.38 DX 64; med res voxel sphere, grow tool, and move tool w/ X symmetry. result: tearing and artifacts. BOTTOM: 3D Coat 4.5.19 DX 64; med res voxel sphere, grow tool, move tool w/ X symmetry. result: smoooooooth! now, i checked the settings of the tools in the two versions. the move degree was 53 instead of 73. and then the move tool seemed to have a different brush tip, so i changed it to the default bell curve. is there some setting i'm missing? i looked in the preferences under Brushing. i thought maybe there was a setting in symmetry, because there appeared to be overlapping interference in the brush radius across the symmetry line, but i didn't find anything about adjustments near the symmetry plane. the resolution is the same (i think??); the number of tris is nearly the same in both examples. just... WHA!?!??!?!?!!! help! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 19, 2016 Report Share Posted September 19, 2016 Hi ! The latest version is 4.7.10 Can you please install it and try again ? Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted September 19, 2016 Contributor Report Share Posted September 19, 2016 Double check if Ignore back faces is turned off. Quote Link to comment Share on other sites More sharing options...
