Member Vykoukal Posted September 19, 2016 Member Report Share Posted September 19, 2016 Hello guys, I´m currently trying to retopo my model and bake normals on it, but when I finish baking (on 4096 resolution) the texture is still jagged and there is a lot of unclear parts... My workflow was modeling basics in voxel mode - adding details in surface mode - autopo - UV mapping (auto-mapping) - baking normal texture. I´ve read that there can be an issue with auto UV mapping, since it´s creating pretty messy UV´s, but I have got really dense mesh so doing this manually would take a lot of time... I´m attaching even one screenshot from paint room, I´ve tried to paint some bump details, but even those are pretty low-res... Could you help me out of this please? I need to put this into Cinema 4D after and into complex scene, which is very hardware-heavy without retopo... Thank you very much in advance! Quote Link to comment Share on other sites More sharing options...
Member Vykoukal Posted September 19, 2016 Author Member Report Share Posted September 19, 2016 Pictures - 1. Scultp 2. retopo wtih UV unwrapping 3. + 4. Paint room details Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 19, 2016 Report Share Posted September 19, 2016 Hi ! Paint Room > View > Show voxels in paint room = is off ? There is a new version, if you like to try Mac OS X [4.7.08]: http://www.3d-coat.com/~sergyi/3D-CoatV4-7-08.dmg Quote Link to comment Share on other sites More sharing options...
Member Vykoukal Posted September 19, 2016 Author Member Report Share Posted September 19, 2016 Hi Carlosan! I somehow figured it out I´ve made cleaner UV cuts and subdivided the texture if I´m expressing myself correctly But another problem appeared in Cinema 4D, as you can see, normal map is working really badly, I´m trying both native and Corona renderers and materials, but both are bad. Do you have any ideas what should i fix there? I think color is exported correctly, but normal map is somehow weird... Thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 19, 2016 Report Share Posted September 19, 2016 version 4.7.10 have Cinema4D export preset, if you like to try - This plugin is useful too http://frostsoft.blogspot.com.ar/p/fssoftware.html Quote Link to comment Share on other sites More sharing options...
Member Vykoukal Posted September 20, 2016 Author Member Report Share Posted September 20, 2016 Awesome! I´m definitely going to try those, really thank you a lot Carlosan! Quote Link to comment Share on other sites More sharing options...
