3D Coat Forums
Shift Studio
[Solved] Depth stopped working in Paint Room
Hi there.
On all types of painting, using regular or smart materials I can't get any depth to paint.
Strength of Brush Depth is set to 100. Layer Blending's 'Depth Opacity' is also set to 100%
Tried on 3D Coat v4.7.7 and v4.5. Using OSX 10.11.6 - El Capitan
Any ideas?
Thanks in advance!
--shift studio.
Hi !
Are you painted a mesh with uvmap ?
cant paint Deep on sculpt surface models.
Just now, Carlosan said:
Hi !
Hi Carlosan.
Yes - I believe I am. I've tried numerous tests, but in particular import OBJ with UV maps or UV Automapping.
Thoughts?
--shift Studio.
First port of call is to make sure that you've enabled painting to depth. Up in your top-bar area you should have three spheres, a blue, green and black one. These are Normals/Depth, Colour, and Gloss/Roughness. If the blue one has a white X over it, it means you're not painting any depth, regardless of what you choose to do.
Edited by Gary Dave
Hi Gary.
Thanks for the response. Yup, I knew that one already. I see I didn't mention it above, but this has been working in the past - its just been the past two or three days.
Whats the second port of call?
Thanks!
Imported normal maps cant be painted over.
can you open a default sample model -shift+M- and try ?
I got it solved - this is embarrassing - in all my testing, I only tried one brush Alpha... and it's 'Brush Option/Depth Modulator' was set to '0'.:blush:
I don't know why??
Thank you Carlosan and Gary - I appreciate your help.
--Shift Studio.
