Michaelgdrs
(InstantLight) real time pbr renderer WITH GLOBAL ILLUMINATION
Michael, I tried to send you a PM message, but it seems you can't receive any. Is your PM box full? :)
Anyway, I attempted to download IL 1.1.52 beta today, but the GDrive contains only one text file in the directory.
Edited by ajz3d
Hey Artur , 1.1.52 was a closed BETA , visible only to selected testers, you can apply at support@instantlightrt.com for further testing on closed BETAS , BUT, in a couple days 1.2.. will be available with many additions / surprises !!!!
Currently 1.1.40 is available for download here ---> https://drive.google.com/drive/folders/0Bx1hDPLcQcmqWEJNMnhtNWpfZlE?usp=sharing
P.S Yeah it was full , so sorry , deleted some.
Edited by Michaelgdrs
It will be a good wait ;)
Instant Light OFFICIAL RELEASE Version 1.2.12
CRUCIAL UPDATE ON OFFICIAL RELEASE
----Core optimisations----
System optimization (1.2.12)
Save / Load optimizations -- Faster save and load , (1.2.12)
UI IMPROVMENTS and SPEED OPTIMISATIONS (1.2.12)
FPS system updated (1.2.12)
Benchmark scene upgraded (1.2.12)
----Render Engine Updates----
Render Engine Internal core got updated (1.2.12)
Render engine updated (1.2.12)
Visuals upgraded , bloom , zdepth added for extra realism , zclip added , issues
with transparent models fixed (1.2.12)
Advance water shader got a re write (1.2.12)
Animation spline system upgraded (1.2.12)
SS system upgraded (1.2.12)
----Additions----
More than 110 new materials added to the materials presets (1.2.12)
Now UI settings and CORE SYSTEM SETTINGS can be saved (1.2.12) (scene setup floating UI)
Polygon cloth enabled and working (1.2.12)
Removed BLUE AND ORANGE icons (1.2.12)
Preview on material presets now shows on mouse hover before click (1.2.12)
UI Themes Light and Grey Dark (1.2.12)
Free Ram instant at scene (1.2.12)
Cornell box added as an extra demo scene (1.2.12)
Procedural Cloth settings presets (1.2.12)
Added save load visual to let user know app is running while save / load (1.2.12)
Procedural cloth vertex got smaller (1.2.12)
Enabled material scale (1.2.12)
3D Coat to Instant Light improvments (1.2.12)
Area Light got a bigger beam (1.2.12)
Area light got new exposed properties on Inspector (1.2.12)
On new scene the G.I setting now go to default (1.2.12)
Added demos folder on Load UI (1.2.12)
----Corrections----
Fixed load scene on welcome screen to NOT loose the icons of editor and look dev (1.2.12)
Rare problem with floating UI visuals fixed (1.2.12)
Header 1 material on off fixed (1.2.12)
Sim stop on Poly cloth not working (1.2.12)
Bend stiffness on poly cloth fixed (1.2.12)
Sim time control on Poly cloth fixed (1.2.12)
Fixed issue with Scene setup floating windows going opaque when pressed.
Now it only goes one time opaque just to save the settings . (1.2.12)
Preview spheres moved to unknown area to prevent visual leaks (1.2.12)
Fixed lag with Poly cloth floating UI
----Known Bugs-----
1) Preset materials cant be saved , will be fixed on next release (1.2.12)
----Near feature Release will contain-----
Poly cloth creation TURN TO MESH AND EXPORT ON DISK (PRIORITY)
SAVE LOAD TRANSFER TO GPU FOR EVEN FASTER SAVE LOAD (PRIORITY)
TEXTURE CREATION ADDON (PRIORITY)
Procedural cloth re add on sim
Poly modelling cloth simulation (from external apps)
Cloth Pins
Decimator keep original mesh and revert to it
Asset Bundle for materials , models etc
User HDRI
WACOM FULL support
www.instantlightrt.com
Review on Instant Light 1.2 new features , including the Polygon cloth Engine
Procedural Cables ADDON for Instant Light RealTime PBR Renderer
(Requires at least a Student / Unemployed PRO version of Instant Light)
Get early access and 50% DISCOUNT by just PRE BUYING
the Procedural cables Add on.
Discount Price : $12,99
Retail Price : $26
Access will be granted to license holders on the next
Instant Light Update.
Uploading Instant Light 1.3.72 with numerous updates , additions and new features!!!!
Unbiased quality presets in render floating menu (1.3.72)
Unbiased timer now varies from 2 seconds to 10 seconds based on quality settings (1.3.72)
NEW experimental shadow catcher working on HDRI now!!! (1.3.72) (disable stochastic reflections for unbiased to work)
User Requests for offline activation (1.3.72)
Procedural cables export , now exports the mesh as well (1.3.72)
Auto cable reset (1.3.72)
Fixed tool-tip of procedural cables (1.3.72)
Among many many others
Uploading Instant Light 1.4.19 with a ton of additions on the Unbiased Engine , tessellation shaders , triplanar shader etc etc
BLACK FRIDAY DEALS COMING UP SOON
Instant Light OFFICIAL RELEASE Version 1.4.19 STABLE - BETA
CRUCIAL BETA UPDATE ON OFFICIAL RELEASE
System optimization (1.4.19)
Save / Load optimizations -- Faster save and load , (1.4.19)
UI IMPROVMENTS and SPEED OPTIMISATIONS (1.4.19)
PRIMITIVES cube sphere plane etc compatible with almost any system in Instant Light (1.4.19)
On new scene , Main Engine system fully auto re boots (1.4.19)
DISPLACEMENT / REALTIME TESSELATION on the advance pbr shader(1.4.19)
TRIPLANAR SHADER works on any model with out UV or UVUNWRAP!!!!! just import your textures and scale
with out seams!!!(1.4.19)
Added white point control on STRT unbiased render engine (1.4.19)
Updated benchmark scene with STRT UNBIASED and TESSELATION (1.4.19)
Shadow catcher now auto disables the stochastic reflections of STRT Unbiased when
we force shadows on the HDRI images , user needs to open them manually (1.4.19)
----Additions----
Procedural cloth added PIN handles , now you can create almost anything very very accurate. (1.4.19)
MatCap materials Monster Clay fully procedural. (1.4.19)
Added STRT UNBIASED render engine in elements (1.4.19)
Primitives can be animated (1.4.19)
Now make cloth interactive gets user interactible only uppon simulation start (1.4.19)
----Corrections----
Droplets and snow secondary textures , needs to re select the model to come up correctly (1.4.19)
Triplanar auto seam transparent color for seamless results (1.4.19)
Start stop sim pins fixed (1.4.19)
Fixed 3d icons on and off bug (1.4.19)
Fixed elements drag (1.4.19)
Fixed HDRI floating ui random anomalies with textures and 3d realtime particle among other issues. (1.4.19)
Tesselation values up (1.4.19)
----Known Issues-----
FBX export works currently on WIN X 64 systems and needs full access under Win 10
TEXTURE CREATION ADDON (PRIORITY / Almost done)
Cloth Pins (FEATURE ADDED)
WACOM FULL support (UPDATED , NEEDS TESTING)
Hello to all friends.
This is my BLACK FRIDAY THANK YOU TO ALL OF YOU  for all the support
and love you shown me so far. A huge thank you from heart.
Here it goes :
TUTORIALS LIFETIME BLACK FRIDAY 2017
https://gumroad.com/products/saLIq/black_friday_tuts_2017
From $199 down to $120 ONLY 5 seats are available.
MATERIALS LIFETIME BLACK FRIDAY 2017
https://gumroad.com/products/KcMl/black_friday_mats_2017
From $199 down to $120 ONLY 10 seats are available.
BRUSHES LIFETIME BLACK FRIDAY 2017
https://gumroad.com/products/EjqcD/black_friday_bru_2017
From $19.99 down to $10 ONLY 10 seats are available.
Instant Light Upgrade from Indie to Pro
BLACK FRIDAY $10 from $20
https://gumroad.com/products/UxjqCq
Instant Light PRO STUDENT - UNEMPLOYED VERSION (Perpetual)
BLACK FRIDAY TO CYBER MONDAY $10 from 19+
https://gumroad.com/products/Qxci
Instant Light INDIE (Perpetual)
BLACK FRIDAY TO CYBER MONDAY $29 from 139
https://gumroad.com/products/blGBJ
Instant Light PRO (Perpetual)
BLACK FRIDAY TO CYBER MONDAY $39 from 139
https://gumroad.com/products/TblE
All Instant Light seats are limited as well.
Again a huge thank you all for the support and i wish you from heart the very best to you , your beloved ones , your family and friends.
Take care.
I want to wish to all of you , one by one ,  a blessing 2018 , FULL of happiness , health and JOY!!!
Personal success on anything you decide to do in life.
I want to truly thank you for all the AMAZING SUPPORT you shown me so far.
I am giving you a crazy sale on everything i have on Gumroad from 30% and up to 70%+ .
PLEASE READ : Make sure you grab whatever you are missing now on this sale as right after the sales i am going to take ALL PRICES UP and start working on new collections for 2018 , with SUPERIOR quality,  lots of Substance files (sbr and sbsar) , PBR Texture creator textures  (my software jejeje that soon will be available to all of you) and a lot more goodies are coming your way.
Merry Christmas (or any other holiday you are into)  to all you.
See you soon.....
Ohhhh i forgot ....
I am also giving gifts to ALL EXISTING AND NEW INSTANT LIGHT USERS!!!!
Kindly visit the site instantlightrt.com or my Gumroad page on Instant Light products for more details!!!
I got contracted a couple days ago and here is the art test that gave me the job/
This also is going to be an upcoming tutorial series for Substance Designer and Instant Light , covering from the very basics in order to trully ubderstant what you are doing with the software's and stepping it up on each series.
Damaged Asphalt Substance Designer / Instant Light
https://www.artstation.com/p/Z1RQZ
SPOILER ALERT
Instant Light 2 ALPHA is coming .... and its going to be UNREAL..... STAY TUNED......
NOTE : Mac Os ALPHA is going to be available from DAY one of the ALPHA for all Mac Os users. ALL Mac Os users will be upgraded to v2 FOR FREE!!!
instantlightrt.com
So it's been over a year since you last posted in this thread. I'm sure you don't want to announce too much and not be able to deliver, but is there any chance of an update on progress, or is this project now dead with your time taken up with your new job? (congratulation on the new job BTW).
What i can say for sure is that we are working on IL2 that is compatible with both Unity / Unreal / Win / MacOs for using it as a render engine inside any game or app.
Licensing for IL 1 has been stopped and all IL1 users will receive IL2 for Free.
  • Like 5
That's great. Thank you for the update. Good luck with it. So how does this fit with "Studio", or is that still to be decided? I'm sure we'd all love to hear more as you feel you can announce more.
Best Regards
Unfortunately we were working on it a year maybe a bit more before studio came out so it was a bit of surprise to see this happening  .
We are looking into that very carefully so we don't get any issues with the main engine.
Will definitely post more as we get more progress on our hands.
Provider went out of business.
Looking for alternative compatible solution to pass existing site.
