Michaelgdrs
(InstantLight) real time pbr renderer WITH GLOBAL ILLUMINATION
First... Thanks for the updated tutorials...
Couple of questions.  I noticed there is no separate roughness channel.  I see metallic and a smoothness slider.
1. I do not see a separate roughness channel like the metallic channel for importing a roughness map.  Example of use would be like for plastic objects, wood. etc.
2. Does the metallic map with the smoothness (roughness in the Alpha channel) in the map itself override the smoothness slider.
I might just be missing the roughness channel as I really just started to test the software.
EDIt: I think I might answer my own question number 1 but question 2 is still vaild.   The renderer is like Unity 5 putting the Smoothness (roughness) in the Alpha channel of the metallic map whereas Unreal 4 uses separate channels for Metallic and  Roughness.  Plastics, wood etc would be handled in the metallic map. Metal in the map would be none and only smoothness (roughness used)
Note:  I added Alpha channel to my question two
Excuse the questions, I know I am late to the party...
Edited by digman
I see you already answered your question on your own.
Smoothness is controlling the  microsurface detail  just like in Unity 5.
Instant Light RC2 2.68.E is uploaded
http://www.instantlightrt.com/
Log
Core optimizations
Engine Core update
SSRR updated
Broswer UI to load faster
DOF Engine updated
Render Engine Updates
Render Engine Core update
Shadow Core Re rewriten
Low poly art mesh convertion
Contact shadows
Skin shader updated
Texture import speed up optimizations
Shadow Catcher must be enabled at the end in order to work currently limitation
Mesh and material save load optimizations
3D Coat bridge upgraded to auto load textures
Additions
Multichannel EXR Render
Short Hair Shader (started working on Long hair system as well)
Low Poly Art shader and mesh convertion
SSS RT Shadows
Contact Shadows for super details in small areas
Interactive measure helpers - lines
Materials and icons for new and current material indicators
Point lights added physical correct attenuation
Version check on log in
Shaders and materials in Res
Corrections
Save load more than 90% done
Grey letters on shaders fixed
S shortcut
UI blockers
Fixed main Sunlight position
Follow camera (just parent main camera onto any animated object and it will follow
based on your view)
Lights do not affect shadow catcher
Soft shadows on point lights
On render floating tab fixed starters
Fixed Advance menus variables
Flash light excludes shadow catcher now
Tab s Tab T works only on Editor room as expected
Ui blocker
Fixed Are soft shadows that got a black background render
On F9 fixed the shader material ball
Fixed SSSRT
Great advance material now show correct shader
Added controls for F12 sequence render
Fixed shadow distance
Fixed issue on some bad modelled models to not cast shadows
Measure lines casting infinite
Very happy to announce
Public RC3 (will be upgraded several times during this week)
(uploading)
Instant Light RC3 3.14.E_2_1
Core optimizations
Engine Core update
Fbx Importer updated for better compatibility
Obj Importer updated for better compatibility
Measure Line Helpers Updated
Save Load now works as expected (needs Administrator setup and full access to perform as expected)
SSS Effects updated
Ao updated
Global Illumination Updated
SSSR updated
Advance Water Shader
Additions
For RC3 we will work on
1)Floating UI for the next updates and finalize save load routines.
2)Offline Login
3)Multiple Cameras setup
Corrections
Fixed F9 bug with UI disappearing
Fixed workflows bug on Load , now after load just pick a worklow (Editor , Split Screen , Realtime) to continue
Huge update coming up for Instant Light today..... stay tuned....
-- INTRODUCING NEW FEATURES--
POLY AND PROCEDURAL CLOTH ENGINE (started implementation , will be revealing features gradually)
Poly Cloth Engine
Import 3d model of cloth and simulate to fit on character / prop
Export to obj / fbx
Procedural Cloth Engine
Create from scratch your cloth
Simulate
Export to obj / fbx
Poly Hair Engine
Import 3d model of Hair and simulate to fit on character
Procedural Hair Engine
Create from scratch your hair , or pick from more than 20 presets
Simulate , animate , render
Export to obj / fbx (later feature)
You starting remind me of Andrew in the early stages of 3DC development, On fire and moving at light speed... :D
Now if I could split me into several version of myself, Learning photoscan more, how to create a good landscape in Unreal 4, World engine a little, and throw in Instant Light in the mix and brain is stretching out big time, LOL but hey it is a good thing, keeps my 64 year brain well oiled...
hahahahah  ha ahahahahahahahaha , now you remind me myself 15 years back maybe 18 when i wanted to do everything and all at the same time.
I will throw a twitch so you can see me braking things especially when compiler gives me hard time lol.
Hey Michael, that's a really amazing update. Do you think that the procedural hair & clothes engine could be one day a plug-in in 3DC ? Or maybe it's not how it works ? I'm on a Mac so I can't try it :/.
My workflow ATM (I'm a concept artist) is : 3DC for sculpting -> MD for the clothes -> zbrush ONLY for fibermesh -> keyshot for shaders & rendering. I have no UVs and I don't retopo. I looking for a way to stop having to use zbrush just for fibermesh. It'd be amazing to have something like this in 3DC, but I know that Andrew is really busy on some other stuffs.
Thanks !
Greetings Mr Panka ,
if you ask me personally i would love to see a tighter integration to 3DC as its my main tool of work regarding many aspects  , and to be honest we are working on this direction to see if we can pass the hair creation , this is under our own testing , we have talked with Andrew in general , and he is positive regarding Instant Light in general.
Andrew  supported me so many times and ways , same with Don , Javis , Carlos and soooooo many other 3D Coat members.
Planning to return those kind gestures , in many ways.
I cant comment on other softwares , all are good in there own way  , Instant Light is my personal creation , a tool to get me all i wanted in work in one app.
More than 2 years in development , never had a UI , all hard coded with command lines.
I will never stop developing , and once out of BETA you will see so many new things coming up.
EXTREMELY happy to announce Instant Light RC3 .86
Core optimisations
Engine Core update
FPS counters updated
Save Load and new scene has been disabled to take the users frustration off.
Internal save load for templates disabled to take the users frustration off
Save LOAD is in its final form , needs some tweaking on speed and it will be
re enabled on RC4
SSS Effects updated
Ao updated
SSSR updated
Advance Core Updated
Fur shader updated
Additions
Offline Login (system works , on next update we will add the users validations)
Look Dev model 360 spin and 360 light spin for metalness check (works on any HDRI)
Look Dev interactive 360 spin
Low poly Hair Simulation (hair must be user made and imported)
Poly hair simulation start stop
Poly hair simulation gravity on off
Character Poser!!!
Character scale helper
Multiple cameras and multiple cameras system
Enabled pre made studios , will be updated on every build
Workflow Automation's to take the new users frustration off
TreeView Reads Names and skeleton bones names now
Floating UI got minimize , pin to position.
Floating UI got a smoother response (needs further tweaking)
Added AUTO safety locks by disabling / enabling buttons on each workflow when they dont have
to be pressed in order to help take the users frustration off
Timeline got its icon
Corrections
Multi channel EXR render fixed
TreeView in its final form
Fixed 3d panel materials
Cloth functions
Shader ball stays hidden after render
On jpg render log now auto turns off
Material icons re position
Look Dev 360 and 360 interactive rotation fast tutorial 1) Select mesh from editor with LEFT click as usual (not from Treeview) 2) RIGHT click on it (not left click on it as the tool-tip says , typo error) 3) Press the Icon
Eager to try this out on a few assets as soon as possible. :)
Could there please be a couple functions added so it can stop draining all the power the whole time?
like a sleep mode when the program is minimized and a stop rendering once the image is "final"?
an FPS limiter could also help, right now it renders with over 220 FPS. ;)
Greetings @myclay ,
a proper tutorial will be uploaded today showing all new features in action.
Regarding your questions / requests
1) Stop rendering can be achieved only in when users is in Editor mode , and with the current Dx 11 and Dx 12 routines it gives bugs.
We are working on an alternative solution
2) FPS must be as high as possible , realtime hair and cloth (currently under heavy development) needs a lot of horse power to get a 40 / 45+ fps.
We want to be be extremely fast and we are tweaking all the time for this to happen.
If you need to get it down you can enable (Nvidia panel) the Vsync and it will drop the FPS down to your monitors FPS.
We are currently working on the settings tab and an FPS drop will be included.
Uploading RC3.90 with 7 bug fixes
On render icon logo goes free
F12 does not return the timeline fixed
DeV icon does not return the timeline fixed
From editor to render room sub routine re checked and fixed
Dev look Icon typo fixed
Floating ui not when minimized does not block model selections
Beta version UI and tooltip ui does not block model selections
ALWAYS use latest BETA
Instant Light RC3 .90 New Features
Poly hair Simulation
Character Poser
Multiple Cameras
EXR Render
Explaining Cloth simulation and creation as well.
Edited by Michaelgdrs
Spoiler from Instant Light RC4 4.70 Internal Beta.
Procedural Hair Gallery and settings
16807724_1909093749310724_37069543315881
Instant Light RC4!!!
Beta is coming to its end GRAB IT NOW WHILE YOU STILL CAN IN SUPER LOW PRICE $40.
Highlights :
INTERACTIVE WEATHERING SYSTEM AND AUTO MATERIAL (ADVANCE CORE) WEATHERING!!!!
SEASON BASED WEATHERING TIMING
ANIMATED SKIES FULL PROCEDURAL
PROCEDURAL HAIR GALLERY READY TO USE ON YOUR MODELS
Instant Light RC4 4.96.F_2_2
Core optimisations
Engine Core update
Fbx Importer updated for better compatibility (2013 - 2015)
Save Load and new scene has been ENABLED for testing.
Due to API changing and CLOTH CREATION (still working on it on the NEW API) we where
forced to get parts out of the code so its limited.
 re enabled on the final RC4 , we are holding for the cloth creation serialization
CORE RENDER ENGINE GOT NEW API!!!!
BRING ANY QUALITY AND WE WILL MATCH AND GIVE BETTER RESULTS TOO!!! (SECURED CODE)
SSS Effects updated
Ao updated
SSSR updated
Fur shader updated
POLY SHADER UPDATED
ADVANCE SUPERB PHOTOREAL QUALITY CARPAINT SHADER
HDRI STUDIO UPDATED BASED ON ACCURATE REAL LIFE MEASURES
Additions
New global light system only for hair
Advance menu got its final PIE menu (hold space click on item , leave space to hide)
AutoFocus
Save load platforms
All save load got higher than materials in stuck
Finalized POLY CLOTH now is ready for final inspections and optimization
Auto hide unhide cameras and camera icons based on users workflow
Material GUI BLOCKERS
Added DELETE restrictions for unlimited point lights and emitters
In editor on selected camera hide 3d icons
Removed shadows from 3d icons (needs also user to disable HD shadows from Render panel or Cam panel)
REMOVED SIMPLE MENU
Added camera selection in Look Dev
AUTO AMBIENT LIGHT BASED ON WEATHERING SYSTEM AND USER HDRI
EXR EXPORT PATH (still testing based on users feedback)
FASTER TEXTURE AND MODELS IMPORT
NEW UI VISUAL updates
Sec Updated
Added Physical camera (reallife model) based Bloom and texture fetch on camera effects
Added collider and WIREFRAME view in Editor and Render room
New starting menu with tutorials , materials etc
Saving loading text and file name , also refers if file is from load (FL) or save (FS)
Corrections
Camera new and add camera new icons
Fixed Tab X
FIXED MIXAMO RIGGING FOR SAVE LOAD AND AUTO RECOGNITION
FIXED CAM IN LOOK DEV
FIXED workflow singge editor screen
FIXED SAVE LOAD bugs due to NEW API CHANGES (still working on it)
Rotation and object recognition updated and fixed for random bugs on runtime
Save Load new co routines
Animation can now be saved and load
Quick Save auto hides
Saving loading texts
Procedural Hair Inputs
Expo op on
Main camera toggle
Global hair lights
Instant Light is getting more and more polished. Very nice work... Even without much tweaking I am liking the render quality.
I sent in a few bug reports today using the newest beta.
The 3DC bridge is that working now?  When I click the 3DC icon in the UI, I get the message shown in the picture.  Maybe I am doing something wrong. 3DC is open, running with the file saved. I am in the paint room with a baked from the retopo room model.
Edited by digman
Greetings David ,
3DC bridge has 2 parts
1) 3D Coat part
2) IL part
Currently only IL part is ready , 3D Coat part will be available shortly i hope.
Will personally check your bug list today , we are under heavy refactoring and API updating currently before the big release.
FIRST OFFICIAL PRE RELEASE
March 15 - 2017
Instant Light PRE RELEASE PR1_049_R_2_1
----Core optimisations----
SAVE LOAD FINALIZED
Main Core UPDATED
Render ENGINE GOT 2 SEPARATED ENGINES FOR STILLS F10 and F11
NEW STILL RENDER ENGINE F11 RENDERS with superior quality and export MASKS!!!
NEW 360 VIDEO RENDER ENGINE
POLY HAIR ALMOST DONE
CLOTH POLY AND PROCEDURAL OUT OF ALPHA WILL BE FULLY ON 1.1 and 1.2
STOP MOTION now Physx respect the particles!!!!!! Stop and start PhysX applies on PARTICLES.
----Render Engine Updates----
NEW RENDER ENGINE F11 RENDERS with superior quality and export MASKS!!!
ALL SCREEN SPACE BASED EFFECTS UPDATED
DOF UPDATED
EXR UPDATED
Toon lines on camera
Eye ADAPTATION ON CAMERA
Secondary DOF (works separate and together with main DOF)
----Additions----
LOOK DEV color Tab
HELP on each icon
LOOK DEV back on second click on its icon
Procedural hair save and load
Shadow catcher add / remove HD shadows and main shadows options
Poly hair saves textures and loads textures for weight now
Poly hair Weight shader / material
EXR writes 12 elements now !!!!
shadow catcher icon on floating menu
New remove preview ball on off
from editor to runtime and opposite shadow catcher auto hides
fixed HDRI floating panel issues
shadow catcher middle mouse click fixed
On new auto finds imported model and deleted it
Added DEFAULT PATH FOR STILL IMAGES C:\Instant_Light_Renders\
Added path selection for still images
Auto LOD on shadow catcher
Particles save load (only one pre made particle , current limitation that we will clear in next builds)
Functions on all rooms to emulate clicks
EXR animations checks path and holds
----Corrections----
On editor no render
Fixed watermark
F11 NEW ENGINE RENDER small render fixed
On F11 UI transparency fixed
Fixed G.I Arrow keys moving background HDRI
DOF HELPER off mouse reach
One scene new deactivate layouts
Last light on load reads properties fine now
Final scene if in render room cameras closing and going back to editor
HDRI floating fixed _ showing up everything
Shadow catcher auto on off , no artefacts , but works only on solid color
On new scene shadow catcher takes it material back
fixed 2d icons auto on off on exr sequense
turn off icons of Look Dev from render on f11
Shadow catcher export image and deactivate auto activate to be off the mask png
Fixed camera after F11
fixed 1080 p mask not rendering
multiple cameras after save load
On new DL GLobal light auto hides
On hair load , hair light opens as well
scale helpers on save load
colliders / wireframe stuck visuals , needs restart of app
procedural cloth panel block view
on welcome screen on inside editor shows pin and _
scale on and off losses expose fixed
timeline disappear fixed
I would really like to see a 3DC to ILRT workflow tut. "Import + Export " One with a simple static and one with a animation. Do you think this can be shown?
JFYI : It is hard to understand you, with all that buzzing in the background
And Will there be a EXPORT to UE4? #Plugin maybe? This is where I would like to see my Art come to life and with your  POLY HAIR / CLOTH POLY  I could see this being apart of my workflow.
Do you plan to add Live Material to Mesh support as well? " Particles"  EXP ( FIRE BALL) ( DUST on Animated Mesh) Would be cool to know.
And will there be a UI Theme changer, I am somewhat C-blind and this blue gives me a very uncanny feeling and kills any interest of trying to get my hands dirty.
Will the UI be in future updates more expandable like used with multi screens? / 4k? ++
I ask kindly before I buy the Full Version
Thank you! :)
I like it, but it still crashes from time to time.
Edited by Speike-Styles
Greetings Speike ,
getting straight into your questions.
3DC / IL is not fully finished yet. We are working on it , more bridges are coming up soon as we made contact with several platform holders and more than 90% where super positive on IL.
Ordered a new mic for the recordings , its the workstations noise that you hear there.
Poly cloth and Procedural cloth are already in (in our version in studio) , hoping to get them both in final Instant Light , was holding this as a surprise but since you asked here they are ;)
Live material to mesh what do you mean? Interactive materials in IL can get in any mesh you import. For Particles onto mesh is in our TODO list , in fact its out of alpha with great results allready , just needs to be polished.
UI theme changer will be in the final IL , in the next coming releases before Final Instant Light.
Multi screens , we have tested so far , but results where not so great , so many things to take under control , we left this for later releases 1.4 1.5.
Crashes is something i care a lot , on my hands , and trust me i use it a looottttt , it crashed 2 times and i knew it was going to crash with the model i imported.
If you remember how it crashed i would like you to send a bug report at support@instantlightrt.com and explain it please.
For buying it , i will just say it as simple as i can , just buy it , you will never regret it , updates are going to be so many and constant (not one tiny SUB feature and call it a version like most apps do nowadays) that IL can easily become your /  to the rescue tool /  very very easily.
And if you buy it for $40 ohh , we dont have to discuss it at all.
Thanks for the link at the Instant Light website for the free Exr-IO plugin for Photoshop. Photoshop compositing for the 12 layers that IL exports in the open exr format. Cool beans... :declare:
Edited by digman
