thinkinmonkey 7 Report post Posted October 11, 2016 Hello, I need help about this: as you can see from images, the normal map created in Substance Designer creates a nice result, I tested it also in Blender. In the first image you can see the normal map imported in 3DC, in the smart material slot, but the result is totally different: why? Thank you. Share this post Link to post Share on other sites
Carlosan 2,497 Report post Posted October 11, 2016 Hi ! Change Preferred Mapping to UV-Mapping Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 Hi Carlos, sorry, I didn't explain correctly: I'm not concerned about the mapping aroung the object, I'm concerning about the fact the normal map seems to be "cut" or "flat". While in Designer and Blender I have this half spheres all around, in 3DC they seems flat, like cylinders or truncated spheres! How is that possible? How can I fix that? Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 Here is it possible to see clearly the spheres over a simple plane as I see in Designer, but not in 3DC Share this post Link to post Share on other sites
Carlosan 2,497 Report post Posted October 11, 2016 can you share the project to take a look ? orizzontale_mask is affecting anything ? Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 (edited) orizzontale_mask is a layer used for the group as mask, switching on/off doesn't affect the bad result. Anyway, I tried with a new 3DC, using the face model at the startup, duplicating a smart material in default (the chrome one) and I added the normal map, but I have the same bad result. I can share with you that normal map, the grid of spheres. Everything started as I saw a difference between Designer and 3DC about a more complex normal map, this is why I'm using that grid of spheres. Please, let me know, because I need to have that fix in order to work. Thank you again for your precious time. Edited October 11, 2016 by thinkinmonkey Share this post Link to post Share on other sites
Carlosan 2,497 Report post Posted October 11, 2016 Please try this. Is the same 32bits image, but without alpha channel -removed- hope this help. //edit i cant paint with fine details using this normal map in a new smart material but looks fine importing the same texture using Texture > Import > NormalMap. - Please send support-related ticket with this issue to Andrew Shpagin at support@3dcoat.com Ty Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 Yeap, exactly! I was sending you a screenshot where it didn't work even with your no_alpha normal map in the smart material, but it works flawlessly if imported as you suggest. Anyway, I'm gonna write Andrew right now. Carlos, thank you again for your time. Michele P.S. If I could, why did you take out the alpha channel in the normal map? There's a particular reason? Share this post Link to post Share on other sites
ajz3d 786 Report post Posted October 11, 2016 No need to use normal map for this. Export height from SD in .exr format and use it as height in your Smart Material. Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 1 hour ago, ajz3d said: No need to use normal map for this. Export height from SD in .exr format and use it as height in your Smart Material. Hi ajz3d, ok, as Andrew answered me: no normal map, but height map. So I changed everything in Designer to work with that. Now, I have a question, for sake of curiosity: why I have strange result if I put 100% in the depth value and I get a good result if I use 5%? I mean, 100% should be using the height map as it is, and putting that value up or down should just enhance or dim the result, right? black__height.exr Share this post Link to post Share on other sites
ajz3d 786 Report post Posted October 11, 2016 (edited) Is depth map from the link the same as used on screenshots? Looks different. Edited October 11, 2016 by ajz3d Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 20 minutes ago, ajz3d said: Is depth map from the link the same as used on screenshots? Looks different. Sorry, ajz3d, I'm doing so many tests, I attached the wrong files. This is the right file! black__height.exr Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 ajz3d, I tried what you were saying, about luminance/height 0 with color 0.5, but I have the same problem: black__height_0.5.exr Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 This is in Designer, the height map coverted to normal map just to be seen in viewport: This is in 3DC, when material Depth is 50% and paiting depth is 50%: This is when material and painting depth are 100% Should I suppose that 50% depth value in smart material says to 3DC: hey, gray is height 0? Share this post Link to post Share on other sites
ajz3d 786 Report post Posted October 11, 2016 Here's how it looks on my 3DC instance. 100% SM depth, 100% brush depth. Maybe your paint layer has depth opacity > 100%, or you made some changes in SM height channel's extended parameters window? Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 11, 2016 ajz3d, I checked what you said, but everything seems normal to me. But now I don't know what to say, because the texture is working right now: I switched to depth & opacity pressure stroke mode and modified the contrast in the sm as you have done and the problem seems gone now. I'll check with the final texture and I'll let you know. For the moment, thank you, guys. Good night Share this post Link to post Share on other sites
digman 1,206 Report post Posted October 12, 2016 Your height map from SD is pure black and white. zero height in 3DC is 127,127,127 gray. White would be 100%. Smart Materials depth is base off the percentage of your setting in the depth setting in the top menu. 100% in the main setting and a setting of 50% in your smart materials = 50% height of the 100% in the top menu. That is how 3DC smart materials work. Always make your SM materials at 100% in the top menu and adjust your percentage of that in the Smart Material. That is my recommendation, less confusing and more so if you share your smart material. 2 Share this post Link to post Share on other sites
thinkinmonkey 7 Report post Posted October 13, 2016 Digman, thank you Share this post Link to post Share on other sites
