Member olmi57 Posted November 10, 2016 Member Report Share Posted November 10, 2016 In UV Room, I have isolated a Paint Object in order to move all of its islands from the "Grey" uv map to the new "Barrel" uv map. No chance to select the whole Paint Object, selecting all respective islands in UV Preview is inappropriate due to the sheer amount of islands. Any idea ? TIA. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 11, 2016 Contributor Report Share Posted November 11, 2016 Have you tried making a selection from the Paint Objects list? You have the 'barrel' visible; select and move it for starters. Quote Link to comment Share on other sites More sharing options...
Member olmi57 Posted November 11, 2016 Author Member Report Share Posted November 11, 2016 As I said, I'm unable to select the "barrel" Paint Object in order to move it to the new uv set. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 12, 2016 Contributor Report Share Posted November 12, 2016 Select it in the viewport using the Select tool in the Retopo room (I never use the UV room, does it have a select tool?). Quote Link to comment Share on other sites More sharing options...
