Member eskay Posted November 14, 2016 Member Report Share Posted November 14, 2016 (edited) I have tired using the clay tool with a stencil to indent the pattern into a voxel cube and had it fail. If I paint onto the cube surface 3D Coat behaves as expected, it builds the surface up leaving the pattern in the cube. If however I hold Ctrl and just click onto the cube surface to indent the pattern the whole pattern is cut through the cube regardless of the depth setting for the brush. Am I doing something wrong or is this a bug? Edited November 14, 2016 by eskay Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 14, 2016 Report Share Posted November 14, 2016 is your project scale very low ? Quote Link to comment Share on other sites More sharing options...
Member eskay Posted November 14, 2016 Author Member Report Share Posted November 14, 2016 The scale doesn't seem to be the issue as the clay tool works as expected except when using Ctrl. Also the other brushes such as the grow, airbrush, carve, build work fine with Ctrl. Quote Link to comment Share on other sites More sharing options...
Member eskay Posted November 14, 2016 Author Member Report Share Posted November 14, 2016 I'm using 3D Coat version 4.7.12. I tried 3D Coat version 4.7.06 and the same issue with the clay tool was happening in the earlier version as well. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 14, 2016 Report Share Posted November 14, 2016 It seems like a bug. //confirmed Quote Link to comment Share on other sites More sharing options...
Member eskay Posted November 14, 2016 Author Member Report Share Posted November 14, 2016 Did you try it and confirm that it is behaving the way I described? If so I will report it as a bug. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 14, 2016 Contributor Report Share Posted November 14, 2016 Just to be sure, was "Ignore Back faces" checked? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 14, 2016 Report Share Posted November 14, 2016 yes in my test Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted November 14, 2016 Reputable Contributor Report Share Posted November 14, 2016 Just tried it in 4.7.13 DX Windows, and using your parameters, it works as expected. Maybe closing the app > deleting the Options.xml file in your MyDocs/3D Coat 4.7 directory will solve it? Quote Link to comment Share on other sites More sharing options...
Member eskay Posted November 15, 2016 Author Member Report Share Posted November 15, 2016 I tried it in 4.7.14 DX before and after deleting the Options.xml file as suggested and I'm still getting the same result. I'll report it as a bug. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 15, 2016 Contributor Report Share Posted November 15, 2016 Two steps forward and one step back. 1 Quote Link to comment Share on other sites More sharing options...
