Arganth
FBX Split up / Unity
Hey my fellow Artists :)
my problem:
what i want: import fbx file and paint them, export the textures and use them in Unity
What I can do: works perfectly with a single fbx file with one mesh
problem: fbx files which hold several other fbx files (armor, bodyparts...) with their own texture sets
When I import it in 3d Coat I get the whole model with all parts kind of randomly lying around in the paint room
is there a way to separate the fbx files? like just getting the armor, painting it, and maybe combine it later again with the main fbx?
Do you assigned different materials to every mesh ?
This setting help your workflow ?
had nearly the same options like you (with unity as the preset where possible)
but you brought me on the right track :)
seems that in my right now limited understanding the whole mesh use 1 uv set
my solution right now is (i can just paint the part i want to (like a helmet))
then export the textures for that and then in unity "extract" that part
and make it a prefab with a new texture :)
what I try next is just to delete the meshes in 3d Coat that i dont need and then just
paint the rest and export that with the texture
Should work too :)
will report after trying that tomorrow :)
thanks to all ;)
Edited by Arganth
