[Solved] redefining standard hotkeys
cerokyn
i would love to reassign these hotkeys because i don't use them
sometimes it works sometimes not
i reassign one of them it said it saved
but when i relaunch its overwrites it to standard
If you like to change manually, is the file
Options_Hotkeys.xml
at
user\Documents\3D-Coat___
  • 1 year later...
hey
i recently reinstall mac os
and 3dcoat too. i have installed new 3.8 (before it was 3.7 i dont remember exactly. i didnt updated for a half a year)
and i wanna use this hotkeys from screenshot above
and now it has conflict i guess.
i tried changed them. i replaced this file from backup
but 3d coat after closing updating this file and adding the hotkey which i changed and rewriting it every time i changing it
so i tried change in application. manually and every time its overwrites it.
and now i even notice it creates about 10 copies of the hotkey i changed in the end of the Options_Hotkeys.xml in the end it said the standard key
this is screenshoots
i tried to change the hotkey and its repalcing it with key_00
and adding brand new copy of this hotkey in the end of the file with the "P" hotkey
its strange because i worked for 2 years its was ok. it just the updated version. and backup file dont changed it as i said. it also get rewritten
i found temporary solution by changing it to some other hotkey.
but can i change it to zero hotkey?
i guess in previsions version it was key_00? and now what
Edited by cerokyn
edit
Please contact support@3dcoat.com to ask this issue.
is there any way to get previous version?
list of stable version releases?
Some old version can be found here.
Or contact support@3dcoat.com to ask for older ones.
Thx
