Member cerokyn Posted December 6, 2016 Member Report Share Posted December 6, 2016 i would love to reassign these hotkeys because i don't use them sometimes it works sometimes not i reassign one of them it said it saved but when i relaunch its overwrites it to standard Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 6, 2016 Report Share Posted December 6, 2016 If you like to change manually, is the file Options_Hotkeys.xml at user\Documents\3D-Coat___ Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted December 6, 2016 Author Member Report Share Posted December 6, 2016 (edited) yes it worked thanks! u can close it if u want Edited December 6, 2016 by cerokyn 1 Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted August 21, 2018 Author Member Report Share Posted August 21, 2018 hey i recently reinstall mac os and 3dcoat too. i have installed new 3.8 (before it was 3.7 i dont remember exactly. i didnt updated for a half a year) and i wanna use this hotkeys from screenshot above and now it has conflict i guess. i tried changed them. i replaced this file from backup but 3d coat after closing updating this file and adding the hotkey which i changed and rewriting it every time i changing it so i tried change in application. manually and every time its overwrites it. and now i even notice it creates about 10 copies of the hotkey i changed in the end of the Options_Hotkeys.xml in the end it said the standard key Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted August 21, 2018 Author Member Report Share Posted August 21, 2018 this is screenshoots i tried to change the hotkey and its repalcing it with key_00 and adding brand new copy of this hotkey in the end of the file with the "P" hotkey its strange because i worked for 2 years its was ok. it just the updated version. and backup file dont changed it as i said. it also get rewritten Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted August 21, 2018 Author Member Report Share Posted August 21, 2018 @Carlosan can u please help thanks Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted August 21, 2018 Author Member Report Share Posted August 21, 2018 (edited) i found temporary solution by changing it to some other hotkey. but can i change it to zero hotkey? i guess in previsions version it was key_00? and now what Edited August 21, 2018 by cerokyn edit Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2018 Report Share Posted August 21, 2018 Please contact support@3dcoat.com to ask this issue. Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted August 21, 2018 Author Member Report Share Posted August 21, 2018 41 minutes ago, Carlosan said: Please contact support@3dcoat.com to ask this issue. is there any way to get previous version? list of stable version releases? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2018 Report Share Posted August 21, 2018 Some old version can be found here. Or contact support@3dcoat.com to ask for older ones. Thx Quote Link to comment Share on other sites More sharing options...
