Member jeric_synergy Posted December 13, 2016 Member Report Share Posted December 13, 2016 (edited) I saw somewhere that it is possible to perform Boolean operations on Volume layers, but haven't been able to discover how. 1) Is this possible? 2) What is the procedure? Specifically, how is Boolean SUBTRACT performed between layers? Tnx! +++ EDIT: I found the function (don't know why RMB on layer name didn't show it up b4, I did try), but the actual subtraction is resulting in some sort of disk caching where the target, subtracted FROM layer is downsampled and converted to a Surface layer??? WUWT? Edited December 13, 2016 by jeric_synergy Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 19, 2016 Report Share Posted December 19, 2016 Boolean operations works better using same layer mode with same density. Quote Link to comment Share on other sites More sharing options...
