Retopo UV tools spacebar Quick access not working?
Beddall
Hey,
In the retopo room , when you press SPACEBAR it brings up the quick select toolbox... in this there are quick access slots #1-8.
firstly... this is an absolute stroke of genius...!!   :)
secondly.... it doesn't seem to work. :(
I just watched a video tutorial so I know i'm using it correctly but nothing happens when i press the hotkeys.... also clicking on the icon in the quick select area doesn't work.
is this a bug?
..also... to add to this... you can still select things that are positioned behind the spacebar menu. this results in you selecting an extra edge or what have you when you are trying to press a button. the actions then get carried out on the edges you wanted plus the extra edge. Is there an option i may have missed to disable that from happening?
cheers
hi,
I'm on version 4.7.06. if i 'check for updates' through the help menu it tells me I am on the latest version....
went to download the latest beta but then saw this...
Do NOT use beta builds in production if build is not marked as [STABLE]
so... guess I wont be downloading that then :)
cheers
Edited by Beddall
added red text
