[Solved] After UV Unwrap Nothing in UV Room
bcgreen24
? I am painting the object in the paint room-- and although I can see my UV's in the retopo room,  I don't see anything in the UV room.
The only way I've made the UV room 'work' is to export my model out as an OBJ and then re-import it-- when I do this, I see the model in the retopo, uv, and paint rooms...
Bryan
Hmm...and now it seems to be working; I did a quick test:
1. Started new project (voxel sculpting)
2. Created a quick test sculpt
3. Ran 'Autopo for Per Pixel' from the right-click menu in the layer
4. Completed auto-retopo in Retopo room
5. Switched to UV room and now see my object with UVs
Not sure why my other project wasn't working; I must have performed some operation that screwed things up.  In any case, I was able to use the 'export/import to obj' workaround for that project, and things are working normally in this test project....
Thanks!
Bryan
