Member Chilton Webb Posted December 29, 2016 Member Report Share Posted December 29, 2016 Hi, Most of the cliff wall I'm working on at the moment looks like this. This is a picture of the real cliff wall. I'm curious how I'd pull off sculpting some of these harsh angles easily in 3D Coat. Thank you! -Chilton Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 29, 2016 Reputable Contributor Report Share Posted December 29, 2016 There are a number of different tools/brushes you could try. In Voxel mode, the PLANE tool and the SCRAPE Brush would be good. There are actually a number of brushes with similar functionality as the Plane Tool built in. You just check to see if the brush/tool has the ON PLANE option in the toolbar (above the viewport). If it does, you can check that and have nearly identical options to set your plane as the PLANE tool. Even the Cutoff tool has it, as does the Flatten Brush, in Surface mode. In the Presets panel, the TRIM preset should be similar to Trim Dynamic in ZB. Polish Crisp is like hPolish in ZB, LC CREASE and LC GROOVE is similar to Dam Standard in ZB. You can tweak the settings (in toolbar, Brush Options panel, etc) and if you want to update the preset, just RMB the preset and choose Update Presets. Quote Link to comment Share on other sites More sharing options...
Member Chilton Webb Posted December 29, 2016 Author Member Report Share Posted December 29, 2016 "You just check to see if the brush/tool has the ON PLANE option in the toolbar (above the viewport)." Hold up, I can't figure out where that is. Is it an icon, or does it say, "ON PLANE"? -Chilton Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 29, 2016 Reputable Contributor Report Share Posted December 29, 2016 3 hours ago, Chilton Webb said: "You just check to see if the brush/tool has the ON PLANE option in the toolbar (above the viewport)." Hold up, I can't figure out where that is. Is it an icon, or does it say, "ON PLANE"? -Chilton It's only available with certain brushes that cut away, like CUTOFF, FLATTEN, and in Voxel mode, CARVE and even VOX HIDE Quote Link to comment Share on other sites More sharing options...
Member Chilton Webb Posted December 29, 2016 Author Member Report Share Posted December 29, 2016 Okay, found it. Thank you! -Chilton 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 30, 2016 Report Share Posted December 30, 2016 Download the 3D-Coat PenPacks (Direct download link) Quote Link to comment Share on other sites More sharing options...
