Tweak Room can't select objects
hello,
this is annoying problem in my workflow i'm usually exploding sub object to bake the normal map and start painting,
and i use Tweak to position back the parts of the objects, but the select objects and select brush does nothing today.
i'm on 4.7.20 opengl 64
You dont need to expolde your objects.
You could do that while baking. Simple check Name Correspndence for Baking.
You find it in the top row under Bake.
All you have to do is to name the voxel objects and retopo layer with the same name.
after more test, i fund, that it works but there is not visual return to see if i have selected an object or not.
previous version were shoing the selected models or vertices in white, wich is not the case now ?
Edited by blackant Master
