Member cerokyn Posted January 16, 2017 Member Report Share Posted January 16, 2017 hi how do i disable this hotkey which brings some preview on screen i am not sure what hotkey it is somethimes it comes with alt shift when navigating its very annoying because i use alt for navigation and shift right away to get top or side view thanks 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 16, 2017 Reputable Contributor Report Share Posted January 16, 2017 ALT + SHIFT + S is what you must be hitting. Either try to avoid hitting those 3 together or see if you can re-assign it. It's UPLOAD SCREENGRAB in the HELP Menu. Quote Link to comment Share on other sites More sharing options...
Member cerokyn Posted January 16, 2017 Author Member Report Share Posted January 16, 2017 thanks a lot Quote Link to comment Share on other sites More sharing options...
Advanced Member Henry Townshend Posted March 2 Advanced Member Report Share Posted March 2 (edited) This is the most workflow breaking default key combo I have ever witnessed. Esp for people who use a ton of hotkeys, Zbrush style, like Shift+Ctrl+Alt+Whatever Key in combination, and working fast, it is almost inevitable to hit these. I wouldn't mind, if the program wouldn't crash guaranteed every single time I accidentally hit it, and often causing me to lose progress, even tho I already save frequently, incrementally, which is Shift+Ctrl+Alt+S for me. I looked into the Help menu and couldn't find what you described @AbnRanger. Could you maybe hint me to how to disable this function in 2024+ ? I browsed the Preferences, but nothing caught my eye so far. Edited March 3 by Henry Townshend add info Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted March 4 Reputable Contributor Report Share Posted March 4 On 3/2/2024 at 8:53 PM, Henry Townshend said: This is the most workflow breaking default key combo I have ever witnessed. Esp for people who use a ton of hotkeys, Zbrush style, like Shift+Ctrl+Alt+Whatever Key in combination, and working fast, it is almost inevitable to hit these. I wouldn't mind, if the program wouldn't crash guaranteed every single time I accidentally hit it, and often causing me to lose progress, even tho I already save frequently, incrementally, which is Shift+Ctrl+Alt+S for me. I looked into the Help menu and couldn't find what you described @AbnRanger. Could you maybe hint me to how to disable this function in 2024+ ? I browsed the Preferences, but nothing caught my eye so far. It looks like Andrew removed it from the HELP menu. Why? I don't know. It stopped working for me for the past few years and I reported it to Andrew. Perhaps they thought it wasn't worth fixing and continuing when Windows now has a built-in screen capture tool? Quote Link to comment Share on other sites More sharing options...
Advanced Member Henry Townshend Posted March 4 Advanced Member Report Share Posted March 4 Thx for having a look and the info. Jeah, seems most reasonable to remove it to not interfere with certain shortcut combos. But of course that would be sad for people using it already and being used to it. I cross fingers it either gets removed or deactivateable again. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 4 Report Share Posted March 4 I forwarded this issue to Andrew I hope he can fix it soon 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Henry Townshend Posted March 5 Advanced Member Report Share Posted March 5 Thx much! I just now realized what it does, as I never clicked "Ok" before: It sends a pic to a non-existing-anymore 404 website So I guess it'd be save to remove. Couple of times I lost progress again in the meantime due to it causing crashing. Quote Link to comment Share on other sites More sharing options...
