Member Rela-x Posted January 18, 2017 Member Share Posted January 18, 2017 Hi, I'm super n00b with 3d coat (and quite noob with max :-D ). I have tried to to make object in 3d coat and I haven't figured out how I could easiest import it to 3ds max 2017 using ptex material. Cant' find tutorial for that process. 3d coat is awesome program! <3 - Rela-x Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 19, 2017 Share Posted January 19, 2017 Hi ! In 3ds Max, go to the File > Import... menu and import the .obj file with the low-level resolution mesh for your object. Make sure that the Retriangulate polygons option in the OBJ importer is disabled. Quote Link to comment Share on other sites More sharing options...
Member Rela-x Posted January 19, 2017 Author Member Share Posted January 19, 2017 Thank you for answer. I can export model from 3d coat and import it to 3ds max 2017, but I don't know how to export ptex texture from 3d coat to max (material). And how to do it without UV mapping (I think ptex does not necessarily need UV mapping. Am I right? ) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 19, 2017 Share Posted January 19, 2017 You right. There is some videos related, please take a look. Quote Link to comment Share on other sites More sharing options...
