Member chippwalters Posted February 9, 2017 Member Report Share Posted February 9, 2017 (edited) When I manually retopo, I get smoothing artifacts even though the UV set is properly mapped. Where is there an export setting for the 'smoothing angle' for poly meshes? Can't seem to find it. I'm using the "Export Retopo Object" menu from the RETOPO room. See this picture. Notice the dark edges on the end-- That's a result of the smoothing (I imported the saved version of the model from the RETOPO room) Now consider the image below. It was imported into SketchUp and the proper smoothing angle applied. Notice no smoothing artifacts. Edited February 9, 2017 by chippwalters Quote Link to comment Share on other sites More sharing options...
Member chippwalters Posted February 11, 2017 Author Member Report Share Posted February 11, 2017 Bump. Anyone know how to do this? Quote Link to comment Share on other sites More sharing options...
