Masking Normal Maps
ghib
  • 3 weeks later...
I use this settings for that task.
I found it resolved.
Thanks again Carlosan, if you look just two posts down I replied to you.
It seems still not resolved in the latest version.
That doesn't work with Imported NormalMaps, yes. It's how it works, its not a bug.
If you have suggestions to change the way of how is working, I advise you to open a ticket for feature request at mantis.
Ty.
  • 1 year later...
  • New Member
Is there a solution for this problem currently? Just as the ghib I loaded a normal map from substance painter and want to use a mask on this but it does not work (or at least not as with diffuse textures.
Hi
Ext Normal maps cant be edited, sorry.
  • New Member
Although I see I can just use a eraser to remove the normal map.. bit destructive but will do for my use now
